Home » Eclipse Projects » GEF » Problem Scrolling in FigureCanvas
Problem Scrolling in FigureCanvas [message #164654] Wed, 19 January 2005 14:05 Go to next message
Originally posted by: eemorale.cs.ucsd.edu
I'm putting a figure in FigureCanvas and it only scrolls down to a
certain point in the figure inside leaving me with only half of the
figure able to viewed. My guess is the problem is with FigureCanvas's
parent object (getContainer()) since I'm in a MultiPageEditorPart.
The following code works fine in a ViewPart when using the parent
object given to you in the "createPartControl" method. I was
wondering if there was a way to get the scrollbar working to scroll
down completely in a MultiPageEditorPart. I've already tried wrapping
getContainer() in a Composite with a layout, but that gives me a blank
figure.
Thanks for your help,
Ernesto
Here's the Code:
FigureCanvas counterExampleCanvas = new FigureCanvas(getContainer(),
new LightweightSystem());
counterExampleCanvas.setBackground(white);
counterExampleCanvas.setScrollBarVisibility(FigureCanvas.ALW AYS);
GridData gridData = new GridData();
gridData.verticalAlignment = GridData.FILL;
gridData.grabExcessVerticalSpace = true;
gridData.grabExcessHorizontalSpace = true;
gridData.horizontalAlignment = GridData.FILL;
counterExampleCanvas.setLayoutData(gridData);
// SequenceDiagramRenderer is a subtype of
Figure
SequenceDiagramRenderer rend = new
SequenceDiagramRenderer(counterExampleMsc);
counterExampleCanvas.setContents(rend);
int index = addPage(counterExampleCanvas );
StringBuffer pageName = new
StringBuffer("CounterExample: ");
pageName.append(i);
setPageText(index, pageName.toString());
Re: Problem Scrolling in FigureCanvas [message #165129 is a reply to message #164654] Fri, 21 January 2005 16:49 Go to previous message
If I understand your problem correctly, you shouldn't be adding different
pages to a figure canvas, rather different figure canvasses to each page.
"Ernesto Morales-Perea" <eemorale@cs.ucsd.edu> wrote in message
news:n8btu0h2gcv0isre39vi5hln7442705qq0@4ax.com...
> figure.
> Ernesto
> Here's the Code:
> Figure
> pageName.append(i);
Previous Topic:Handling REQ_OPEN requests
Next Topic:AbstractEditPart.refreshChildren refreshes one level only
Current Time: Sat Jul 19 07:00:49 EDT 2025
Powered by FUDForum. Page generated in 0.08185 seconds
