Home » Eclipse Projects » Eclipse Platform » Get MultiPageEditorPart from MultiPageEditorActionBarContributor
Get MultiPageEditorPart from MultiPageEditorActionBarContributor [message #163419] |
Fri, 28 November 2003 19:38  |
Using the multi-page editor example, I have create my own editor. Now,
I want to use the MultiPageEditorActionBarContributor code to action a menu
bar icon to perform some validation on what is in the editor.
How do I get the currently active MultiPageEditorPart instance when the
menu bar icon is selected.
The example just kicks off a Message Dialog, but doesn't show how to call
a method in the original editor. When the menu bar item is selected, I
want to call a method (validateArtifact) back in my MeetingEditor object
to operate on the editor contents.
Any help would be appreciated.
Example:
MeetingEditor.java - my multi-page editor
public class MeetingEditor extends MultiPageEditorPart {
public void validateArtifact() {
MeetingEditorContributor.java - shows the pulldown and menu item for editor
NOTE: See commented section below.
public class MeetingEditorContributor extends
MultiPageEditorActionBarContributor {
private IEditorPart activeEditorPart;
private Action sampleAction;
* Creates a multi-page contributor.
public MeetingEditorContributor() {
super();
createActions();
* Returns the action registed with the given text editor.
* @return IAction or null if editor is null.
protected IAction getAction(ITextEditor editor, String actionID) {
return (editor == null ? null : editor.getAction(actionID));
public void setActivePage(IEditorPart part) {
if (activeEditorPart == part)
return;
activeEditorPart = part;
IActionBars actionBars = getActionBars();
if (actionBars != null) {
ITextEditor editor = (part instanceof ITextEditor) ? (ITextEditor) part
: null;
actionBars.setGlobalActionHandler(
IWorkbenchActionConstants.DELETE,
getAction(editor, ITextEditorActionConstants.DELETE));
IWorkbenchActionConstants.UNDO,
getAction(editor, ITextEditorActionConstants.UNDO));
IWorkbenchActionConstants.REDO,
getAction(editor, ITextEditorActionConstants.REDO));
IWorkbenchActionConstants.CUT,
getAction(editor, ITextEditorActionConstants.CUT));
IWorkbenchActionConstants.COPY,
getAction(editor, ITextEditorActionConstants.COPY));
IWorkbenchActionConstants.PASTE,
getAction(editor, ITextEditorActionConstants.PASTE));
IWorkbenchActionConstants.SELECT_ALL,
getAction(editor, ITextEditorActionConstants.SELECT_ALL));
IWorkbenchActionConstants.FIND,
getAction(editor, ITextEditorActionConstants.FIND));
IWorkbenchActionConstants.BOOKMARK,
getAction(editor, ITextEditorActionConstants.BOOKMARK));
actionBars.updateActionBars();
private void createActions() {
sampleAction = new Action() {
public void run() {
// I want to call back to MeetingEditor object's validateArtifact method
// instead of this MessageDialog call
MessageDialog.openInformation(null, "editor Plug-in", "Sample Action
Executed");
sampleAction.setText("Validate Artifact");
sampleAction.setToolTipText("Validate Artifact");
sampleAction.setImageDescriptor(PlatformUI.getWorkbench().ge tSharedImages().
getImageDescriptor(ISharedImages.IMG_OBJS_TASK_TSK));
public void contributeToMenu(IMenuManager manager) {
IMenuManager menu = new MenuManager("&Artifact");
manager.prependToGroup(IWorkbenchActionConstants.MB_ADDITION S, menu);
menu.add(sampleAction);
public void contributeToToolBar(IToolBarManager manager) {
manager.add(new Separator());
manager.add(sampleAction);
Re: Get MultiPageEditorPart from MultiPageEditorActionBarContributor [message #163463 is a reply to message #163419] |
Sat, 29 November 2003 00:01   |
Originally posted by: sma_r.hotmial.com
I think if you want the instance of the MultiPageeditorPart you can try
the following code(i think this is what you might need).
IWorkbench workbench = PlatformUI.getWorkbench();
IWorkbenchWindow window = workbench.getActiveWorkbenchWindow();
IWorkbenchPage page = window.getActivePage();
IEditorPart part = page.getActiveEditor();
I hope this helps you.
Syed
> Example:
> super();
> createActions();
> return;
> : null;
> public void run() {
> Executed");
Re: Get MultiPageEditorPart from MultiPageEditorActionBarContributor [message #163718 is a reply to message #163463] |
Sun, 30 November 2003 12:42   |
That gets me the visible editor on the page I'm on. What I'm looking for
is how do I get the instance of the object that created the editor page.
I need to call the "validateArtifact" method that is part of my object
extended from MultiPageEditorPart.
Let me try a different way: Open two different files with the same
editor (that I created from extending MultiPageEditorPart). I then push
the button was created by a MultiPageEditorActionBarContributor. How
do I get the instance of the editor that is currently active and not the
other one?
> Syed
> > Example:
> > super();
> > createActions();
> > return;
> > : null;
> > public void run() {
> > Executed");
Re: Get MultiPageEditorPart from MultiPageEditorActionBarContributor [message #163726 is a reply to message #163718] |
Sun, 30 November 2003 13:35   |
Originally posted by: bob.objfac.com
"Don Dunne" <donald.g.dunne@boeing.com> wrote in message
news:bqda6f$ot$1@eclipse.org...
> other one?
setActivePage() is called before you are asked to run. If you want the
MultiPageEditorPart instead of the active editor within that part, override
setActiveEditor() and remember it.
Bob
> > Syed
Now,
menu
the
call
I
object
> > > Example:
editor
> > > super();
> > > createActions();
> > > return;
part
> > > : null;
> > > public void run() {
method
> > > Executed");
Re: Get MultiPageEditorPart from MultiPageEditorActionBarContributor [message #163775 is a reply to message #163726] |
Sun, 30 November 2003 15:00  |
That did it, thanks!!
> > other one?
> Bob
> > > Syed
> Now,
> menu
> the
> call
> I
> object
> > > > Example:
> editor
> > > > super();
> > > > createActions();
> > > > return;
> part
> > > > : null;
> > > > public void run() {
> method
> > > > Executed");
Current Time: Sat Jul 19 18:44:14 EDT 2025
Powered by FUDForum. Page generated in 0.26046 seconds
