Eclipse Installtion Problem on Win-2000 [message #163220] |
Fri, 28 November 2003 05:00  |
Originally posted by: notennadaiit.yahoo.com
I downloaded and unzipped eclipse. But, when I tried to install it, I got a
message informing me that my installation was unsuccessful, and that I ought
to look in .log in .metadata in .workspace for more info.
Below is the exception stored in .log. I would appreciate it if someone
could help me install it properly.
____________________________________________________________ _____________
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:861)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:767)
at org.eclipse.core.launcher.Main.main(Main.java:601)
at org.eclipse.ui.keys.KeyStroke.hashCode(KeyStroke.java:517)
at java.util.HashMap.hash(HashMap.java:250)
at java.util.HashMap.get(HashMap.java:301)
at
org.eclipse.ui.internal.commands.KeySequenceBindingNode.add( KeySequenceBindi
ngNode.java:174)
at
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateTree(KeyS
equenceBindingMachine.java:223)
at
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateSolution(
KeySequenceBindingMachine.java:202)
at
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.g etKeySequenceBin
dingsByCommandId(KeySequenceBindingMachine.java:72)
at
org.eclipse.ui.internal.commands.CommandManager.calculateKey SequenceBindings
(CommandManager.java:270)
at
org.eclipse.ui.internal.commands.CommandManager.readRegistry (CommandManager.
java:688)
at
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:2
29)
at
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:1
92)
at
org.eclipse.ui.commands.CommandManagerFactory.getCommandMana ger(CommandManag
erFactory.java:41)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:736)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1358)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:237)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at
a:858)
... 8 more
____________________________________________________________ ______________
FUDForum. Page generated in 0.04056 seconds
