Home » Language IDEs » ServerTools (WTP) » Specify crossContext=true for tomcat?
Specify crossContext=true for tomcat? [message #162220] Mon, 27 February 2006 11:46 Go to next message
Is this possible using WTP?
-barry
Re: Specify crossContext=true for tomcat? [message #162303 is a reply to message #162220] Mon, 27 February 2006 15:49 Go to previous messageGo to next message
Barry,
You can add it to the <Context> element in the server.xml of the Tomcat
configuration under the Servers project of your workspace.
Alternatively, you can include it in the <Context> element in a
META-INF/context.xml in the WebContent folder of your project. The
later approach has the advantage of not getting lost if you remove and
re-add your project to a Tomcat server.
Larry
> -barry
Re: Specify crossContext=true for tomcat? [message #162403 is a reply to message #162303] Tue, 28 February 2006 10:46 Go to previous messageGo to next message
So even though WTP will dynamically create a server.xml when tomcat
starts with a <Context> element, the META-INF/context.xml will get
merged in with that, or replaced?
-barry
Larry Isaacs wrote:
> Barry,
> Tomcat configuration under the Servers project of your workspace.
> Cheers,
> Larry
>> -barry
Re: Specify crossContext=true for tomcat? [message #162424 is a reply to message #162403] Tue, 28 February 2006 11:21 Go to previous messageGo to next message
The child elements of the <Context> in META-INF/context.xml will replace
any found in the <Context> present in server.xml found under the Servers
project. Attributes of <Context> from context.xml will be copied to the
the <Context> that comes from server.xml, excluding "path" and
"docBase". I think that's basically how its handled, though I might be
forgetting some minor detail.
Larry
> -barry
> Larry Isaacs wrote:
>> Barry,
>> Cheers,
>> Larry
>>> -barry
Re: Specify crossContext=true for tomcat? [message #162432 is a reply to message #162424] Tue, 28 February 2006 13:47 Go to previous message
Perfect. Thanks very much Larry!
> replace any found in the <Context> present in server.xml found under
> the Servers project. Attributes of <Context> from context.xml will be
> copied to the the <Context> that comes from server.xml, excluding
> "path" and "docBase". I think that's basically how its handled,
> though I might be forgetting some minor detail.
> Larry
>> -barry
>> Larry Isaacs wrote:
>>> Barry,
>>> and re-add your project to a Tomcat server.
>>> Cheers,
>>> Larry
>>>> -barry
Previous Topic:init() method for a deployed webservice?
Next Topic:Contributing tabs and sections to the WSDL Editor
Current Time: Sat Jul 19 12:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.04921 seconds
