Home » Eclipse Projects » EGit / JGit » Remove project from EGIT(How to put a project back to normal workspace)
Remove project from EGIT [message #1578671] Thu, 22 January 2015 09:48 Go to next message
I have recently started to use egit. The project, that I have been training the usage of EGIT with, was moved out of Eclipse's regular workspace and into the GIT working directory after I put it under version control.
Is there a way to put the project back to normal Eclipse workspace if I do no longer want to have it under version control?
Thanks in advance.
Re: Remove project from EGIT [message #1579297 is a reply to message #1578671] Thu, 22 January 2015 17:47 Go to previous messageGo to next message
* Select the project e.g. in Project Explorer or Package Explorer
* Click "Refactor > Move"
Re: Remove project from EGIT [message #1583814 is a reply to message #1579297] Sun, 25 January 2015 06:17 Go to previous messageGo to next message
That did the trick.
Thanks.
Re: Remove project from EGIT [message #1621217 is a reply to message #1583814] Tue, 17 February 2015 14:07 Go to previous messageGo to next message
@Matthias
Yes, works for me too ... if you want to take files out of version control...
Er, but what if you don't? I don't know how to put this gently: THIS IS A MASSIVE BUG.
Thus, the first thing you try out as a newb with your plugin, following the only lucid instructions available about Egit, namely vogella, actually leaves Eclipse in an inconsistent state!
Given that this is a plugin whose only function is to work with Eclipse, shouldn't you be doing something about this as a matter of urgency? NB logged as a bug in November 2014: Eclipse bugs 451521
As it stands your plugin is not currently fit for purpose and, worse, is shipped as standard with the Eclipse Luna distro.
[Updated on: Tue, 17 February 2015 14:22] by Moderator
Re: Remove project from EGIT [message #1622984 is a reply to message #1621217] Wed, 18 February 2015 16:49 Go to previous message
Try to be a bit more polite and try with a current EGit version.
Vogella is a good source for instructions but it's for sure not the only source of documentation for EGit:
http://lmgtfy.com/?q=EGit+tutorial
Previous Topic:JGIt: pulling across directories.
Next Topic:Git Pull introduces unstaged changes
Current Time: Sat Jul 19 16:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.03600 seconds
