NullPointerException in Hudson [message #1619330] |
Mon, 16 February 2015 08:59  |
I get following exception when I want to build my E4 RCP project with
Hudson (version 3.2.1) and Maven (version 3.2.5, Tycho 0.22.0):
Found mavenVersion 3.2.5 from file
jar:file:/opt/apache-maven-3.2.5/lib/maven-core-3.2.5.jar!/META-INF/maven/org.apache.maven/maven-core/pom.properties
Parsing POMs
ERROR: Processing failed due to a bug in the code. Please report this to
dev@xxxxxxxx.net
at hudson.FilePath.isAbsolute(FilePath.java:214)
at hudson.FilePath.<init>(FilePath.java:202)
at hudson.FilePath.child(FilePath.java:940)
at
hudson.maven.MavenModuleSetBuild$RunnerImpl.doRun(MavenModuleSetBuild.java:570)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:524)
at hudson.model.Run.run(Run.java:1493)
at hudson.maven.MavenModuleSetBuild.run(MavenModuleSetBuild.java:420)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
project=MavenModuleSet[MyProject]
project.getModules()=[MavenModule[MyProject/my.project:my.project.module1][MyProject/my.project:my.project.module1][relativePath:null],
MavenModule[MyProject/my.project:my.project][MyProject/my.project:my.project][relativePath:null],
MavenModule[MyProject/my.project:my.project.module2][MyProject/my.project:my.project.module2][relativePath:null],
MavenModule[MyProject/my.project:my.project.module3][MyProject/my.project:my.project.module3][relativePath:null],
MavenModule[MyProject/my.project:my.projectmodule4][MyProject/my.project:my.projectmodule4][relativePath:null],
MavenModule[MyProject/my.project:my.project.module5][MyProject/my.project:my.project.module5][relativePath:null],
MavenModule[MyProject/my.project:my.project.module6][MyProject/my.project:my.project.module6][relativePath:null],
MavenModule[MyProject/my.project:my.project.master][MyProject/my.project:my.project.master][relativePath:],
MavenModule[MyProject/my.project:my.project.module7][MyProject/my.project:my.project.module7][relativePath:null],
MavenModule[MyProject/my.project:my.project.product][MyProject/my.project:my.project.product][relativePath:null]]
project.getRootModule()=MavenModule[MyProject/my.project:my.project.master][MyProject/my.project:my.project.master][relativePath:]
FATAL: null
at
The project gets properly built under Windows/Linux using the integrated
Maven 3.2.1 of the Eclipse Luna workbench.
The project "my.project.master" defines the parent pom that also defines
the contained modules.
The parent sections of my modules look like this:
<parent>
<groupId>my.project</groupId>
<artifactId>my.project.master</artifactId>
<version>0.0.1-SNAPSHOT</version>
<relativePath>../my.project.master/pom.xml</relativePath>
</parent>
When I manually build the Hudson working copy using "mvn clean verify",
everything gets compiled properly. So, it seems to be a Hudson problem.
I couldn't find a solution for this problem. Does anybody have an idea
what is going wrong and can point into the right direction.
Thanks a lot!
Stefan
FUDForum. Page generated in 0.03355 seconds
