Faces Context Not Found - Portal [message #1607452] |
Sun, 08 February 2015 17:54  |
I created a Dynamic Project with Process Server Facets. Then tried to run on Tomcat server. When you try to access the portal you get the following error. This happens on Mac Yosemite and Windows 7.
Error:
SEVERE: Servlet.service() for servlet [jsp] in context with path [/demo-startdust] threw exception [javax.faces.FacesException: Faces context not found. getResponseWriter will fail. Check if the FacesServlet has been initialized at all in your web.xml configuration fileand if you are accessing your jsf-pages through the correct mapping. E.g.: if your FacesServlet is mapped to *.jsf (with the <servlet-mapping>-element), you need to access your pages as 'sample.jsf'. If you tried to access 'sample.jsp', you'd get this error-message.] with root cause
at javax.faces.webapp.UIComponentTag.setupResponseWriter(UIComponentTag.java:926)
at javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag.java:313)
at org.apache.myfaces.taglib.core.ViewTag.doStartTag(ViewTag.java:73)
at org.apache.jsp.index_jsp._jspx_meth_f_005fview_005f0(index_jsp.java:101)
at org.apache.jsp.index_jsp._jspService(index_jsp.java:76)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:140)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
FUDForum. Page generated in 0.43461 seconds
