Home » Language IDEs » ServerTools (WTP) » Webtools 1.0 running on Kanotix/Debian
Webtools 1.0 running on Kanotix/Debian [message #159821] |
Thu, 09 February 2006 08:11  |
Originally posted by: eclipse.burchard-net.de
I have Problems running Webtools under Kanotix.
the J2EE perspektiv doesn't work.
Many wizards break with errors...
I post the errorlog. Can somebody help me?
Regards Martin
> !SESSION 2006-02-09 10:25:40.02 ------------------------------------------------
> eclipse.buildId=M20050929-0840
> java.fullversion=GNU libgcj 4.0.3 20060121 (prerelease) (Debian 4.0.2-7j1)
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
> Command-line arguments: -os linux -ws gtk -arch x86
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:21.945
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.core (86).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(org.osgi.framework.BundleActivator) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart() (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t() (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String, boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(java.lang.String, boolean) (Unknown Source)
> at java.lang.ClassLoader.loadClass(java.lang.String) (/usr/lib/libgcj.so.6.0.0)
> at java.lang.VMClassLoader.resolveClass(java.lang.Class) (/usr/lib/libgcj.so.6.0.0)
> at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.6.0.0)
> at java.lang.reflect.Constructor.newInstance(java.lang.Object[] ) (/usr/lib/libgcj.so.6.0.0)
> at org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation() (Unknown Source)
> at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation() (Unknown Source)
> at org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin () (Unknown Source)
> at org.eclipse.core.internal.compatibility.PluginActivator.star t(org.osgi.framework.BundleContext) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run() (Unknown Source)
> at java.security.AccessController.doPrivileged(java.security.Pr ivilegedExceptionAction) (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.OutOfMemoryError
> <<No stacktrace available>>
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:22.87
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (180).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle org.eclipse.jdt.ui.
> at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(java.lang.String, boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(org.osgi.framework.Bundle, java.lang.String, java.lang.Object, org.eclipse.core.internal.registry.ConfigurationElement, java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(java.lang.String, java.lang.String, java.lang.Object, org.eclipse.core.internal.registry.ConfigurationElement, java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(java.lang.String) (Unknown Source)
> at org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory() (Unknown Source)
> at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(org. eclipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Perspective.createPresentation(org.e clipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Perspective.Perspective(org.eclipse. ui.internal.registry.PerspectiveDescriptor, org.eclipse.ui.internal.WorkbenchPage) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.createPerspective(org. eclipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.init(org.eclipse.ui.in ternal.WorkbenchWindow, java.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.WorkbenchPage(org.ecli pse.ui.internal.WorkbenchWindow, java.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(java.la ng.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> Caused by: java.lang.NoClassDefFoundError: while resolving class: org.eclipse.jdt.internal.ui.JavaPlugin
> at java.lang.VMClassLoader.transformException(java.lang.Class, java.lang.Throwable) (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.ClassNotFoundException: org.eclipse.jdt.core.WorkingCopyOwner
> Root exception:
> !ENTRY org.eclipse.ui 4 4 2006-02-09 10:26:22.426
> !MESSAGE Could not create intro part.
> !ENTRY org.eclipse.ui 4 4 2006-02-09 10:26:22.427
> !STACK 1
> org.eclipse.ui.PartInitException: Abnormal Workbench Condition
> at org.eclipse.ui.internal.WorkbenchPage.showView(java.lang.Str ing, java.lang.String, int) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.showView(java.lang.Str ing) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchIntroManager.createIntro(or g.eclipse.ui.IWorkbenchWindow) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(org. eclipse.ui.IWorkbenchWindow, boolean) (Unknown Source)
> at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro( ) (Unknown Source)
> at org.eclipse.ui.internal.ide.IDEWorkbenchWindowAdvisor.openIn tro() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.open() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(ja va.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$10(org.eclipse.ui.i nternal.Workbench) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$15.run() (Unknown Source)
> at org.eclipse.ui.internal.Workbench$16.run(org.eclipse.core.ru ntime.IProgressMonitor) (Unknown Source)
> at org.eclipse.jface.operation.ModalContext.runInCurrentThread( org.eclipse.jface.operation.IRunnableWithProgress, org.eclipse.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.jface.operation.ModalContext.run(org.eclipse.jfa ce.operation.IRunnableWithProgress, boolean, org.eclipse.core.runtime.IProgressMonitor, org.eclipse.swt.widgets.Display) (Unknown Source)
> at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(boolean, boolean, org.eclipse.jface.operation.IRunnableWithProgress) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.runStartupWithProgress(int , java.lang.Runnable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.openFirstTimeWindow() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow() (Unknown Source)
> at org.eclipse.ui.application.WorkbenchAdvisor.openWindows() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.init(org.eclipse.swt.widge ts.Display) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.runUI() (Unknown Source)
> !SUBENTRY 1 org.eclipse.ui 4 0 2006-02-09 10:26:22.494
> !MESSAGE Abnormal Workbench Condition
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:37.411
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.team.core (89).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.team.internal.core.TeamPlugin.start() of bundle org.eclipse.team.core.
> at org.eclipse.core.internal.resources.Workspace.initializeTeam Hook() (Unknown Source)
> at org.eclipse.core.internal.resources.Workspace.getTeamHook() (Unknown Source)
> at org.eclipse.core.internal.resources.Rules.Rules(org.eclipse. core.internal.resources.Workspace) (Unknown Source)
> at org.eclipse.core.internal.resources.Workspace.getRuleFactory () (Unknown Source)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(org.ec lipse.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.core.internal.events.AutoBuildJob.run(org.eclips e.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.core.internal.jobs.Worker.run() (Unknown Source)
> at .GC_start_routine (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.NoClassDefFoundError: while resolving class: org.eclipse.team.core.Team
> at org.eclipse.team.internal.core.TeamPlugin.start(org.osgi.fra mework.BundleContext) (Unknown Source)
> Caused by: java.lang.ClassNotFoundException: org.eclipse.team.internal.core.FileContentManager
> Root exception:
> !SESSION 2006-02-09 10:30:39.613 -----------------------------------------------
> !ENTRY org.eclipse.ui.workbench 4 2 2006-02-09 10:30:55.110
> !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
> !STACK 0
> java.lang.reflect.InvocationTargetException
> at org.eclipse.ui.internal.Workbench.restoreState(org.eclipse.u i.IMemento) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$12(org.eclipse.ui.i nternal.Workbench, org.eclipse.ui.IMemento) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$17.run() (Unknown Source)
> at org.eclipse.core.internal.runtime.InternalPlatform.run(org.e clipse.core.runtime.ISafeRunnable) (Unknown Source)
> at org.eclipse.core.runtime.Platform.run(org.eclipse.core.runti me.ISafeRunnable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.restoreState() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org. eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse. swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
> at org.eclipse.ui.internal.ide.IDEApplication.run(java.lang.Obj ect) (Unknown Source)
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(ja va.lang.Object) (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.Object) (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[], java.lang.Runnable) (Unknown Source)
> at java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (/usr/lib/libgcj.so.6.0.0)
> at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[], java.net.URL[]) (Unknown Source)
> at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown Source)
> at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown Source)
> Caused by: java.lang.NullPointerException
> at org.eclipse.ui.internal.WorkbenchPage.restoreState(org.eclip se.ui.IMemento, org.eclipse.ui.IPerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.restoreState(org.ecl ipse.ui.IMemento, org.eclipse.ui.IPerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.doRestoreState(org.eclipse .ui.IMemento, org.eclipse.core.runtime.MultiStatus) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$14(org.eclipse.ui.i nternal.Workbench, org.eclipse.ui.IMemento, org.eclipse.core.runtime.MultiStatus) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$19.run() (Unknown Source)
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:31:01.197
> !STACK 0
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:31:01.351
> !STACK 0
Current Time: Sat Jul 19 10:50:20 EDT 2025
Powered by FUDForum. Page generated in 0.09267 seconds
