SPARC Simulator + GDB + CDT + Eclipse [message #159475] |
Wed, 30 November 2005 12:29  |
Originally posted by: fabricio.dea.inpe.br
Hi all,
After a lot of help from Norbert and Mikhail I could put GDB to work with
my development board, using the Zylin plugin
(http://www.zylin.com/embeddedcdt.html).
However, I have to do the same with the SPARC Instruction Simulator (SIS),
as we have just one board and some developers (it's an ERC32 processor, a
very expensive one) to work with it.
When starting a debug session on the real processor everything works fine.
But when trying to do the same with SIS, there's no answer to the last GDB
command, "run".
I can debug the simulator directly from the command line, and even using
the DDD graphical interface to GDB. But not with Eclipse / CDT.
I ran gdb from Eclipse and from the command line (with "interpreter=mi"),
and there's some differences between the sessions.
(A session with Eclipse)
[1.132.204.637.358] (gdb)
[1.132.204.641.145] 7 tar sim
[1.132.204.641.162] &"tar sim\n"
[1.132.204.641.165] ~"Connected to the simulator.\n"
[1.132.204.641.190] 7^done
[1.132.204.641.193] 8 load
[1.132.204.641.194] (gdb) [1.132.204.641.227] &"load\n"
[1.132.204.641.249] 8^done
[1.132.204.641.252] 9 break Init
[1.132.204.641.253] (gdb) [1.132.204.641.280] &"break Init\n"
[1.132.204.641.318] 9^done
[1.132.204.641.325] 10 run
[1.132.204.641.328] (gdb) [1.132.204.641.344] &"run\n"
(and there's no other message)
(A command-line session)
(gdb)
tar sim
&"tar sim\n"
^done
(gdb)
load
&"load\n"
^done
(gdb)
break Init
&"break Init\n"
^done
(gdb)
run
&"run\n"
^done,reason="breakpoint-hit",bkptno="1",thread-id="0",
frame={addr="0x02001210",func="Init",args=[{name="ignored ",value="0"}],
file="hello.c",line="13"}
(gdb)
As you can see, from the command line we know that the breakpoint was hit,
but not from Eclipse. What can be happening?
Thanks in advance,
Fabrício.
FUDForum. Page generated in 0.08835 seconds
