Home » Language IDEs » ServerTools (WTP) » Publishing a webapp is not complete
Publishing a webapp is not complete [message #159924] Thu, 09 February 2006 13:00 Go to next message
Originally posted by: emerxill.msn.com
WTP isn't completely publishing my webapps. I only publishes the directory structure, my classes and a few other files but not all of them. E.g. my jar's aren't being copied nor my jsp-pages.
This way it's impossible for me to debug...
Can somebody explain me what to do?
Thnx
Re: Publishing a webapp is not complete [message #160042 is a reply to message #159924] Thu, 09 February 2006 22:02 Go to previous messageGo to next message
The webtools seem to be pretty buggy or at least i am missing same major
config setting.
check your ../workspace/yourproject/WebContent/WEB-INF directory against
.../workspace/.metadata/.plugins/org.eclipse.wst.server.core /tmp0/webapps/yourproject/WEB-INF
i experience that most of the times the web.xml and lib directory are
missing and i have to copy them by hand.
also files in the /WEB-INF/classses/ root directory make trouble from
time to time.
as they get deleted from time to time try fiddling around with your
write permission. this approach seems not to be working under windows.
the same problems appear in the webttools 1.5M4 and all the latest
integration builds. so don't waste your time trying around.
tell me if i am wrong. i would love to get these problems solved as they
cost me a lot of time.
cheers
max
> Thnx
Re: Publishing a webapp is not complete [message #160058 is a reply to message #160042] Fri, 10 February 2006 01:48 Go to previous messageGo to next message
Yep, web.xml and lib are missing... I am working now the way you are suggesting and it's a solution for one project, the other is bit of a problem.
Re: Publishing a webapp is not complete [message #160114 is a reply to message #160042] Fri, 10 February 2006 09:33 Go to previous messageGo to next message
I am experiencing similar problems and checked with what you suggested.
First of all, I did see the web.xml and lib directories along the first
path as you had suggested. Regarding the second path, I have tmp0 and
tmp1 directories under my path. I believe that I am using my tmp1
directory structure, don't know where this got set but that is the only
directory that appears to have anything in it.
Under the tmp1 directory I have a webapps directory but beneath that there
is no list of my project. The only directory under there is a ROOT
directory with a WEB-INF directory beneath it. That WEB-INF directory has
nothing in it.
There was a \work\Catalina\localhost\myproject\ directory structure under
them tmp1 directory though. However, that one did not have a web.xml or
lib directory either.
I expect that my service is not being deployed. If you have any
suggestions I would appreciat it. Especially since I don't see my project
listed under the webapps directory.
Ben
Re: Publishing a webapp is not complete [message #160216 is a reply to message #160114] Fri, 10 February 2006 13:37 Go to previous messageGo to next message
try to get all my postings on this list. you should find all possible
solutions there.
a short summary.
1.delete your server(s) and create new.
2. try a clean rebuild of your project
3. copy the web.xml and lib dir by hand to your tmpX folder (should only
be one if you have one project). classes folder should be copied by
eclipse, but if not copy it as well.
4. do a fresh eclipse install. get teh zips and don't forget the -clean
option the first time.
these options are not in order.
TOO ANYONE: help us please. there are many people having trouble with
the deployment on tomcat. as it just file handling it cna't be that hard
compared what your plugin does on the other hand. any help is really
really appreciated!
cheers
max
> there is no list of my project. The only directory under there is a
> ROOT directory with a WEB-INF directory beneath it. That WEB-INF
> directory has nothing in it.
> under them tmp1 directory though. However, that one did not have a
> web.xml or lib directory either.
> project listed under the webapps directory.
> Ben
Re: Publishing a webapp is not complete [message #160279 is a reply to message #160216] Fri, 10 February 2006 15:36 Go to previous messageGo to next message
forgot one thing. go to project properties and at the end you find the
XDoclet settings.
add the library. helped a bit for me. but still sometimes all gets
messed up with the following errors:
11.02.2006 07:32:19 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/BedFiller] startup failed due to previous errors
any ideas on that?
cheers
max
> solutions there.
> a short summary.
> really appreciated!
> cheers
> max
>> suggested. First of all, I did see the web.xml and lib directories
>> along the first path as you had suggested. Regarding the second path,
>> I have tmp0 and tmp1 directories under my path. I believe that I am
>> using my tmp1 directory structure, don't know where this got set but
>> that is the only directory that appears to have anything in it.
>> Thanks,
>> Ben
Re: Publishing a webapp is not complete [message #160312 is a reply to message #160279] Fri, 10 February 2006 17:03 Go to previous message
the error message was my fault. but the xdoclet stuff might help anyway.
cheers
max
> XDoclet settings.
> any ideas on that?
> cheers
> max
>> solutions there.
>> a short summary.
>> only be one if you have one project). classes folder should be copied
>> by eclipse, but if not copy it as well.
>> -clean option the first time.
>> hard compared what your plugin does on the other hand. any help is
>> really really appreciated!
>> cheers
>> max
>>> path, I have tmp0 and tmp1 directories under my path. I believe that
>>> I am using my tmp1 directory structure, don't know where this got set
>>> but that is the only directory that appears to have anything in it.
>>> Thanks,
>>> Ben
Previous Topic:How to programatically get the content from a JavaScript editor
Next Topic:Programatically finding out if the editor document is valid?
Current Time: Sun Jul 20 09:56:49 EDT 2025
Powered by FUDForum. Page generated in 0.30212 seconds
