Home » Modeling » GMF (Graphical Modeling Framework) » Open an editor from an action
Open an editor from an action [message #158855] Thu, 08 November 2007 06:29 Go to next message
Originally posted by: trommas.yahoo.com
Hi all!
What would be the correct way to initialize an editor from an action
(ex. a popup action)
Best Regards,
Tomas Zijdemans
Re: Open an editor from an action [message #158903 is a reply to message #158855] Thu, 08 November 2007 06:59 Go to previous messageGo to next message
Hi Tomas,
Take a look at the generated XYZDiagramEditorUtil.openDiagram(Resource)
method.
Boris
Tomas Zijdemans wrote:
> Hi all!
> Best Regards,
> Tomas Zijdemans
Re: Open an editor from an action [message #158925 is a reply to message #158903] Thu, 08 November 2007 07:23 Go to previous messageGo to next message
Thanks Boris.
Though I am a bit confused. The method looks like this:
IWorkbenchPage page = PlatformUI.getWorkbench()
..getActiveWorkbenchWindow().getActivePage();
page.openEditor(new URIEditorInput(diagram.getURI()), XYZDiagramEditor.ID);
Should it be called with a valid resource, or should I mimic it's
behaviour (copy/paste).
Tomas Zijdemans
Boris Blajer wrote:
> Hi Tomas,
> method.
> Best regards,
> Boris
>> Hi all!
>> Best Regards,
>> Tomas Zijdemans
Re: Open an editor from an action [message #158933 is a reply to message #158925] Thu, 08 November 2007 07:35 Go to previous messageGo to next message
Hi Tomas,
Probably, I have misunderstood you. I have assumed that you have a
resource or at least URI thereof (in the latter case, you should create
a new editing domain and load the resource with this URI into its
resource set). Was my assumption correct?
Boris
> Thanks Boris.
> Tomas Zijdemans
> Boris Blajer wrote:
>> Hi Tomas,
>> XYZDiagramEditorUtil.openDiagram(Resource) method.
>> Best regards,
>> Boris
>>> Hi all!
>>> Best Regards,
>>> Tomas Zijdemans
Re: Open an editor from an action [message #158962 is a reply to message #158933] Thu, 08 November 2007 08:13 Go to previous messageGo to next message
Well basically what I want to do, is add a new action to a model
elements popup that initializes a new diagram of some type. The best
thing would be if it just executed the code that gets executed when one
creates a new diagram from the file menu.
That should be pretty straight forward? (Initializing it with no
questions asked would be even better)
I found this, but I am unsure about the procedure:
http://wiki.eclipse.org/index.php/GMF_Archived_Newsgroup_Q&a mp;A#How_can_I_open_an_editor_by_double-clicking_a_compartme nt.3F
Boris Blajer wrote:
> Hi Tomas,
> Best regards,
> Boris
>> Thanks Boris.
>> Thanks,
>> Tomas Zijdemans
>> Boris Blajer wrote:
>>> Hi Tomas,
>>> Best regards,
>>> Boris
>>>> Hi all!
>>>> Best Regards,
>>>> Tomas Zijdemans
Re: Open an editor from an action [message #158985 is a reply to message #158962] Thu, 08 November 2007 09:07 Go to previous messageGo to next message
Hi Tomas,
This is a common task that is supported by GMF with no need for
hand-written code. Please search for "OpenDiagramBehavior" in the
newsgroup, since this topic is not discussed in details in the wiki.
Boris
> Boris Blajer wrote:
>> Hi Tomas,
>> create a new editing domain and load the resource with this URI into
>> its resource set). Was my assumption correct?
>> Best regards,
>> Boris
>>> Thanks Boris.
>>> Thanks,
>>> Tomas Zijdemans
>>> Boris Blajer wrote:
>>>> Hi Tomas,
>>>> Best regards,
>>>> Boris
>>>>> Hi all!
>>>>> action (ex. a popup action)
>>>>> Best Regards,
>>>>> Tomas Zijdemans
Re: Open an editor from an action [message #164367 is a reply to message #158985] Wed, 05 December 2007 08:54 Go to previous messageGo to next message
I've implemented OpenDiagram behavior (using double click behavior from
diagram partitioning). I also need to start up an editor from a popup
action. Is it possible to do this?
Any help, and especially code snippets, appreciated :)
Best Regards,
Tomas Zijdemans
Boris Blajer wrote:
> Hi Tomas,
> Best regards,
> Boris
>> one creates a new diagram from the file menu.
>> Boris Blajer wrote:
>>> Hi Tomas,
>>> Best regards,
>>> Boris
>>>> Thanks Boris.
>>>> Thanks,
>>>> Tomas Zijdemans
>>>> Boris Blajer wrote:
>>>>> Hi Tomas,
>>>>> Best regards,
>>>>> Boris
>>>>>> Hi all!
>>>>>> Best Regards,
>>>>>> Tomas Zijdemans
Re: Open an editor from an action [message #164913 is a reply to message #164367] Mon, 10 December 2007 12:38 Go to previous message
Hi Tomas,
If your node has the OpenDiagram behavior installed, and the action
should be invocable on the EditPart, you may simply obtain an instance
of the edit part (e.g., from IStructuredSelection) and execute
editPart.performRequest(new Request(RequestConstants.REQ_OPEN)) on it.
Boris
> Best Regards,
> Tomas Zijdemans
> Boris Blajer wrote:
>> Hi Tomas,
>> Best regards,
>> Boris
>>> Boris Blajer wrote:
>>>> Hi Tomas,
>>>> Best regards,
>>>> Boris
>>>>> Thanks Boris.
>>>>> Thanks,
>>>>> Tomas Zijdemans
>>>>> Boris Blajer wrote:
>>>>>> Hi Tomas,
>>>>>> Best regards,
>>>>>> Boris
>>>>>>> Hi all!
>>>>>>> Best Regards,
>>>>>>> Tomas Zijdemans
Previous Topic:RCP problem
Next Topic:Create child view without serialization of the correspondant Element
Current Time: Sun Jul 20 03:44:14 EDT 2025
Powered by FUDForum. Page generated in 0.07717 seconds
