Home » Modeling » OCL » Reusing OCL in a profile
Reusing OCL in a profile [message #1587384] |
Tue, 27 January 2015 05:02  |
Dear all,
When adding OCL to a profile in Papyrus, I would like to factorize OCL
code to improve maintainability. For instance, if I have in two
stereotypes an attribute of type TypeA, I would like to write just once
the constraints and then invoke them from both stereotypes.
Is it possible when specifying the constraints in the profile?
Víctor
Re: Reusing OCL in a profile [message #1587567 is a reply to message #1587527] |
Tue, 27 January 2015 07:22   |
Thanks Ed.
I don't know exactly how to create helpers in the Constraint element in
the profile specification. Since it is a helper function, Should I need
to specify a Context or I should use a parameter instead with no Context
specification. I guess a parameter would be the right way. However, I
can't find the exact syntax to create helper functions in the profile.
Víctor
El 27/01/2015 a las 12:50, Ed Willink escribió:
> Hi
> UML Constraints are not re-useable, which is clearly very irritating.
> Graphically there is no problem in drawing multiple lines from a
> Constraint and functionally these could be the various
> Constraint.constrainedElement values. Unfortunately the
> Constraint.constrainedElement values are underspecified and almost an
> irrelevance. It is the one Constraint.context that defines the context
> of the Constraint and consequently makes it un-reuseable.
> You can define a helper operation that can be invoked from multiple
> constraints and so avoid repetitive complex OCL expressions.
> Regards
> Ed Willink
> On 27/01/2015 10:02, "V. López" wrote:
>> Dear all,
>> once the constraints and then invoke them from both stereotypes.
>> Regards,
>> Víctor
Re: Reusing OCL in a profile [message #1587718 is a reply to message #1587567] |
Tue, 27 January 2015 09:15   |
A helper 'function' is just a query Operation, probably with an
OCL-defined body. It can have as many parameters as you like.
Ed Willink
On 27/01/2015 12:22, "V. López" wrote:
> Thanks Ed.
> in the profile specification. Since it is a helper function, Should I
> need to specify a Context or I should use a parameter instead with no
> Context specification. I guess a parameter would be the right way.
> However, I can't find the exact syntax to create helper functions in
> the profile.
> Regards,
> Víctor
>> Hi
>> Regards
>> Ed Willink
>>> Dear all,
>>> Regards,
>>> Víctor
Re: Reusing OCL in a profile [message #1587865 is a reply to message #1587718] |
Tue, 27 January 2015 11:00   |
Thanks again Ed for your quick answer.
I've used queries in Acceleo, the problem is that I don't how to do it
Please, find attached two images. In the first one (OCL01.png) there is
a OCL constraints which works OK. Now what I would like to achieve is
what is shown in OCL02.png. That is, factorize the constraint by
invoking the query, but I must be missing something or the syntax I'm
using it's not OK.
I wonder if it is possible.
Best,
Víctor
El 27/01/2015 a las 15:15, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> Thanks Ed.
>> the profile.
>> Regards,
>> Víctor
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Dear all,
>>>> Regards,
>>>> Víctor
Re: Reusing OCL in a profile [message #1587904 is a reply to message #1587865] |
Tue, 27 January 2015 11:31   |
Sorry, forgot to attached the images.
Please, find them attached.
Víctor,
> using it's not OK.
> Best,
> Víctor
>> Hi
>> Regards
>> Ed Willink
>>> Thanks Ed.
>>> the profile.
>>> Regards,
>>> Víctor
>>>> Hi
>>>> Regards
>>>> Ed Willink
>>>>> Dear all,
>>>>> Regards,
>>>>> Víctor
Attachment: OCL01.png
(Size: 17.60KB, Downloaded 280 times)
Attachment: OCL02.png
(Size: 32.64KB, Downloaded 297 times)
Re: Reusing OCL in a profile [message #1588002 is a reply to message #1587718] |
Tue, 27 January 2015 12:46   |
to be clearer
A helper 'function' is a UML Operation that is a query and has a body
'constraint' defined using OCL.
Ed Willink
On 27/01/2015 14:15, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Thanks Ed.
>> the profile.
>> Regards,
>> Víctor
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Dear all,
>>>> Regards,
>>>> Víctor
Re: Reusing OCL in a profile [message #1589424 is a reply to message #1588002] |
Wed, 28 January 2015 07:36   |
Thanks Ed, now I found some documentation on the topic here:
http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FOCLinPapyrus.html
However, there are some issues I can't solve.
In the image attached I try to add a Helper class with a query operation
that I try to call from another Constraint in a Stereotype.
But I'm not able to find out how to do it properly.
Is there an example somewhere where the invocation of the query is shown.
Víctor López-Jaquero
El 27/01/2015 a las 18:46, Ed Willink escribió:
> Hi
> to be clearer
> Regards
> Ed Willink
>> Hi
>> Regards
>> Ed Willink
>>> Thanks Ed.
>>> the profile.
>>> Regards,
>>> Víctor
>>>> Hi
>>>> Regards
>>>> Ed Willink
>>>>> Dear all,
>>>>> Regards,
>>>>> Víctor
Attachment: OCL03.png
(Size: 28.79KB, Downloaded 295 times)
Re: Reusing OCL in a profile [message #1589531 is a reply to message #1589424] |
Wed, 28 January 2015 08:59   |
It's a normal OO functional call
someObject.someFunction()
Ed Willink
> operation that I try to call from another Constraint in a Stereotype.
> Regards,
>> Hi
>> to be clearer
>> Regards
>> Ed Willink
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Thanks Ed.
>>>> the profile.
>>>> Regards,
>>>> Víctor
>>>>> Hi
>>>>> context
>>>>> Regards
>>>>> Ed Willink
>>>>>> Dear all,
>>>>>> factorize OCL
>>>>>> Regards,
>>>>>> Víctor
Re: Reusing OCL in a profile [message #1591341 is a reply to message #1589531] |
Thu, 29 January 2015 08:22  |
I got it working with a test example by using operations as queries. I
added an stereotype (abstractStereotype) where the operations are
defined. The other stereotype (relationshipC) has a generalization
relationship with this abstractStereotype. This abstractStereotype is an
extension of the metaclass Dependency. Then I write something like after
specifying the operation in the abstractStereotype:
CheckProfiles(self.base_Dependency) (as an OCL in relationshipC
stereotype).
This works.
Nevertheless, when I try to do the same with a model where the profile
is within a package it doesn't work.
Should I change something when calling the operation? I always get the
same error:
The 'RelationshipC::ConstraintTest' constraint result is invalid for
'«RelationshipC»profile::0'
- Failed to evaluate
profile::Test::AbstractDependency::CheckProfiles(UML::Dependency) :
Boolean <<RelationshipC>> <Dependency> 0 profile EMF Problem
I checked the OCL body of the operation by using a regular constraint
and it works.
Víctor
El 28/01/2015 a las 14:59, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> Regards,
>>> Hi
>>> to be clearer
>>> Regards
>>> Ed Willink
>>>> Hi
>>>> Regards
>>>> Ed Willink
>>>>> Thanks Ed.
>>>>> the profile.
>>>>> Regards,
>>>>> Víctor
>>>>>> Hi
>>>>>> context
>>>>>> Regards
>>>>>> Ed Willink
>>>>>>> Dear all,
>>>>>>> factorize OCL
>>>>>>> Regards,
>>>>>>> Víctor
Current Time: Sat Jul 19 13:37:14 EDT 2025
Powered by FUDForum. Page generated in 0.05173 seconds
