Home » Language IDEs » ServerTools (WTP) » How to add WebSphere 5.1 runtime
How to add WebSphere 5.1 runtime [message #158376] Sun, 29 January 2006 23:25
I used WTP for some days. It's amazing. For the same project I was
working on, WTP always controlled the memory usage around 150MB. While
for the same project, I used RAD6 which quickly eat up 400MB of memory and
kept growing.
Now the issue is, my target server is WAS 5.1, which cannot be found in
WTP. I don't wanna use WAS 6.0. How I can add WAS5.1 support into WTP?
It seems the only issue for me till now. Since for entity beans, I can
still use xDoclet to manually create, modify bean source file and WTP will
handle the build process.
Any other plug-in, such as JSF, Struts, I don't need them. I prefer to
write in hand.
With XML, Web services, JSP, HTML, Java Script inside, what else you want?
for me, it's enough except for support of WAS 5.1
Previous Topic:Using XML-Editor and keeping EMF-Model in sync by changing xml-content with xml-editor
Next Topic:What is proper in Dynamic Web Project?
Current Time: Sat Jul 19 19:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.04135 seconds
