Web Viewer.display(): Parameter "frameset" don't workfor on an e(fx)eclipse rcp applicatio [message #1581073] |
Fri, 23 January 2015 16:56  |
I'm on an e(fx)clipse rcp application and want to generate a raport via birt
here is my code
String path = "";
try {
Bundle bundle = bundle = Platform.getBundle("mypluginId");
if(bundle!=null)
System.out.println(bundle.toString());
else{
System.out.println("bundle null");
return;
URL url = FileLocator.find(bundle, new Path("stock.rptdesign"), null);
path = FileLocator.toFileURL(url).getPath();
} catch (MalformedURLException me) {
System.out.println("Fehler bei URL " + me.getStackTrace());
} catch (IOException e) {
System.out.println("Fehler bei URL " + e.getStackTrace());
browser = new Browser(parent, SWT.NONE);
// use the filename of your report
WebViewer.display(path, WebViewer.HTML, browser, "frameset");
My problem is the line
when I use the parameter "run" it's ok but if I use "frameset" I have this on the view HTTP ERROR: 500
Problem accessing /viewer/frameset. Reason:
Server Error
Powered by Jetty://
and this is the error I have in the console
janv. 23, 2015 10:41:39 PM org.apache.jasper.compiler.JDTJavaCompiler$1 findType
GRAVE: Compilation error
org.eclipse.jdt.internal.compiler.classfmt.ClassFormatException
at org.eclipse.jdt.internal.compiler.classfmt.ClassFileReader.<init>(ClassFileReader.java:372)
at org.apache.jasper.compiler.JDTJavaCompiler$1.findType(JDTJavaCompiler.java:358)
at org.apache.jasper.compiler.JDTJavaCompiler$1.findType(JDTJavaCompiler.java:315)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.askForType(LookupEnvironment.java:113)
at org.eclipse.jdt.internal.compiler.lookup.UnresolvedReferenceBinding.resolve(UnresolvedReferenceBinding.java:49)
at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.resolveType(BinaryTypeBinding.java:122)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.getTypeFromTypeSignature(LookupEnvironment.java:1335)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.getTypeFromVariantTypeSignature(LookupEnvironment.java:1391)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.getTypeArgumentsFromSignature(LookupEnvironment.java:1172)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.getTypeFromTypeSignature(LookupEnvironment.java:1340)
at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.createMethod(BinaryTypeBinding.java:550)
at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.createMethods(BinaryTypeBinding.java:630)
at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.cachePartsFrom(BinaryTypeBinding.java:365)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.createBinaryTypeFrom(LookupEnvironment.java:688)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.createBinaryTypeFrom(LookupEnvironment.java:667)
at org.eclipse.jdt.internal.compiler.Compiler.accept(Compiler.java:296)
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.askForType(LookupEnvironment.java:142)
at org.eclipse.jdt.internal.compiler.lookup.PackageBinding.getTypeOrPackage(PackageBinding.java:183)
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findImport(CompilationUnitScope.java:487)
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findSingleImport(CompilationUnitScope.java:541)
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.faultInImports(CompilationUnitScope.java:369)
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.faultInTypes(CompilationUnitScope.java:466)
at org.eclipse.jdt.internal.compiler.Compiler.process(Compiler.java:756)
at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:468)
at org.apache.jasper.compiler.JDTJavaCompiler.compile(JDTJavaCompiler.java:494)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:384)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:453)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:625)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:492)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:378)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.equinox.jsp.jasper.JspServlet.service(JspServlet.java:155)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:76)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:457)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:229)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.Dispatcher.include(Dispatcher.java:183)
at org.eclipse.equinox.http.servlet.internal.RequestDispatcherAdaptor.include(RequestDispatcherAdaptor.java:37)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:82)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.callBack(AbstractBaseFragment.java:106)
at org.apache.jsp.webcontent.birt.pages.dialog.DialogContainerFragment_jsp._jspService(org.apache.jsp.webcontent.birt.pages.dialog.DialogContainerFragment_jsp:105)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:111)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:403)
at org.apache.jsp.webcontent.birt.pages.layout.SidebarFragment_jsp._jspService(org.apache.jsp.webcontent.birt.pages.layout.SidebarFragment_jsp:75)
at org.apache.jsp.webcontent.birt.pages.layout.ReportFragment_jsp._jspService(org.apache.jsp.webcontent.birt.pages.layout.ReportFragment_jsp:75)
at org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment_jsp._jspService(org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment_jsp:163)
at org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.service(FramesetFragment.java:98)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(ViewerServlet.java:181)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:368)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:942)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1004)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:640)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:628)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
janv. 23, 2015 10:41:42 PM org.apache.jasper.compiler.Compiler generateClass
GRAVE: Error compiling file: D:\eclipsefx\eclipse\Myworkspace\.metadata\.plugins\org.eclipse.pde.core\pmemanager\org.eclipse.osgi\bundles\361\data\jettywork\pid_2037686139\proxytemp\hc_1372646511\org\apache\jsp\webcontent\birt\pages\dialog\PrintReportServerDialogFragment_jsp.java
I really what to get the rederer via framset in oder to get the toolbar on my webviewer.
Thanks.
Re: Web Viewer.display(): Parameter "frameset" don't workfor on an e(fx)eclipse rc [message #1581147 is a reply to message #1581073] |
Fri, 23 January 2015 17:55   |
My wild guess is that the compiler shipped with jetty is unable to read
java8 class files which it has to do to compile jsp-Files.
Tom
On 23.01.15 22:56, Frederic PAPY wrote:
> birt
> here is my code
> String path = "";
> try {
> if(bundle!=null)
> else{
> return;
> Server Error
> Powered by Jetty:// and this is the error I have in the console
> findType
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> generateClass
> on my webviewer.
> Thanks.
FUDForum. Page generated in 0.04815 seconds
