Home » Language IDEs » C / C++ IDE (CDT) » Cannot set breakpoints
Cannot set breakpoints [message #158069] |
Tue, 15 November 2005 17:59  |
Hi -
I'm using Eclipse 3.1, CDT 3.0.1. I find that I cannot set breakpoints
in a C++ project (using managed make - haven't tried standard make). The
debug perspective will open, and I _can_ run the gdb debugger. Its just
that the options to set breakpoints are grayed out in the Run... menu,
and Ctrl-Shift-B only makes a "B"(with underscore) symbol appear briefly
at the cursor, then it disappears.
I've tried it with my current project, but also with a vanilla "Hello
World" type CDT managed make project. No luck.
Any ideas?
Dan
Re: Cannot set breakpoints [message #158148 is a reply to message #158100] |
Wed, 16 November 2005 13:44   |
Nothing happens when I double click the ruler. But this question led me
to the solution -- I'm using the colorer editor plugin version 0.7.1
(http://colorer.sourceforge.net/). When I removed the plugin, I can set
breakpoints once again.
I couldn't discern any colorer settings which would enable/disable this
behavior, and a cursory trip through the colorer site didn't yield any
clues, either. I'll post a question on their forum later today.
Thanks for your help, Mikhail.
Dan
Mikhail Khodjaiants wrote:
> What happens when you double click on the ruler of the editor?
> "Daniel Sperka" <djsperka@ucdavis.edu> wrote in message
> news:dldp09$1bs$1@news.eclipse.org...
>>Hi -
>>Any ideas?
>>Thanks,
>>Dan
Re: Cannot set breakpoints [message #158173 is a reply to message #158148] |
Wed, 16 November 2005 14:11   |
Originally posted by: mikhailk.qnx.com
Do you have the same problem with Java files?
news:dlfuea$qsb$1@news.eclipse.org...
> Nothing happens when I double click the ruler. But this question led me to
> Dan
>>>Hi -
>>>Any ideas?
>>>Thanks,
>>>Dan
Re: Cannot set breakpoints [message #158209 is a reply to message #158173] |
Wed, 16 November 2005 17:06   |
Java files do not have the same problem! In other words, when I replaced
the colorer plugin (0.7.1) in my plugins folder and created a little
"Hello World" project, I could place breakpoints there by
double-clicking the ruler. (Obviously, the same is true when I remove
colorer plugin.).
Oddly, I found that when my c++ project had breakpoints set (which I had
done after I removed colorer), and then re-installed colorer, the
breakpoints still showed up in the ruler. I still couldn't double-click
and add new ones, nor could I double-click on the existing breakpints to
remove them.
Sounds like some problem with the combination of colorer (0.7.1 at
least) and the CDT editor.
Dan
>>Dan
>>>>Hi -
>>>>Any ideas?
>>>>Thanks,
>>>>Dan
Re: Cannot set breakpoints [message #158215 is a reply to message #158173] |
Wed, 16 November 2005 17:16   |
FYI - bug submitted to colorer.sf.net:
http://sourceforge.net/tracker/index.php?func=detail&aid =1358493&group_id=34855&atid=413324
Dan
>>Dan
>>>>Hi -
>>>>Any ideas?
>>>>Thanks,
>>>>Dan
Re: Cannot set breakpoints [message #158239 is a reply to message #158209] |
Thu, 17 November 2005 10:36   |
I'll install colorer and try to reproduce the problem. Maybe we do something
illegal in the CDT.
news:dlga8q$ci6$1@news.eclipse.org...
> "Hello World" project, I could place breakpoints there by double-clicking
> the ruler. (Obviously, the same is true when I remove colorer plugin.).
> remove them.
> Sounds like some problem with the combination of colorer (0.7.1 at least)
> and the CDT editor.
> Dan
>>>Dan
>>>>>Hi -
>>>>>The
>>>>>briefly
>>>>>Any ideas?
>>>>>Thanks,
>>>>>Dan
Re: Cannot set breakpoints [message #158295 is a reply to message #158209] |
Thu, 17 November 2005 14:16  |
As I have found out, the colorer plugin provides its own editor which
doesn't support breakpoint actions. If open a C/C++ file using C editor, you
will get the breakpoints actions.
> remove them.
> and the CDT editor.
> Dan
>>>Dan
>>>>>Hi -
>>>>>The
>>>>>briefly
>>>>>Any ideas?
>>>>>Thanks,
>>>>>Dan
Current Time: Sat Jul 19 10:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.24465 seconds
