Home » Eclipse Projects » Remote Application Platform (RAP) » Localization of JFace MessageDialog(Localization of JFace Buttons)
Localization of JFace MessageDialog [message #1580382] Fri, 23 January 2015 08:08 Go to next message
I'm trying to translate the buttons of a JFace MessageDialog. In English they are shown with "OK" and "Cancel". But in German they still are shown with "OK" and "Cancel".
I created the RAP Hello World example.
Added this to
BasicEntryPoint#createContents
MessageDialog.openConfirm(button.getShell(), "Title", "Buttons should be translated");
BasicApplication
public void configure(Application application ) {
    application.setOperationMode( OperationMode.SWT_COMPATIBILITY );
Copied the messages.properties from the org.eclipse.rap.jface... plugin to my plugin under src.org.eclipse.jface and renamed it to messages_de.properties. And did change the strings to
ok=OK
cancel=Abbrechen
build.properties looks like
bin.includes = META-INF/,\
               OSGI-INF/,\
               src/org/eclipse/jface/messages_de.properties
PS:
RWT.getLocale() is de_DE
The Cancel Button still has the text "Cancel". What am i missing?
[Updated on: Fri, 23 January 2015 08:23] by Moderator
Re: Localization of JFace MessageDialog [message #1580407 is a reply to message #1580382] Fri, 23 January 2015 08:28 Go to previous messageGo to next message
First of all, the Eclipse Babel project [1] provides community-managed language packs for various languages, and I invested some time to add the necessary German translations for RAP bundles. You can download the language packs from their website [2].
Depending on your build and runtime enviroment you'll need to update your target definition and make sure that the required fragments with the translations are part of your launch configuration.
Fragments? Bundles? I think here's the error in your setup. If I understand you correctly you were copying property files into your own bundle and translated them there. Unfortunately this is not how Eclipse searches for translations. You'll need to create a fragment that has the corresponding RAP bundle as host and put the language specific property files into this fragment.
But... as I wrote above... the easiest solution is to use the already available language packs from Babel.
[1] http://eclipse.org/babel/
[2] http://eclipse.org/babel/downloads.php
Markus
Re: Localization of JFace MessageDialog [message #1580426 is a reply to message #1580407] Fri, 23 January 2015 08:42 Go to previous messageGo to next message
Tanks a lot for your quick reply.
A Fragment was the key for the solution.
I created a fragment with org.eclipse.rap.jface as host and added the messages_de.properties there.
I also added this fragment in the launch configuration. And all is done.
Thanks again!
I will look at Babel the next days.
Re: Localization of JFace MessageDialog [message #1580445 is a reply to message #1580426] Fri, 23 January 2015 08:53 Go to previous messageGo to next message
It's really worth looking at it because nearly all RAP strings are translated into German.
Have a nice weekend,
Markus
Re: Localization of JFace MessageDialog [message #1601997 is a reply to message #1580445] Thu, 05 February 2015 03:52 Go to previous messageGo to next message
In my case it is exactly the opposite. My own strings are translated correctly in english, when i switch the language.
But the MessageDialog Buttons are always shown in german (my default system language).
Anyone an idea?
Re: Localization of JFace MessageDialog [message #1602049 is a reply to message #1601997] Thu, 05 February 2015 04:35 Go to previous messageGo to next message
Are you using Babel?
Re: Localization of JFace MessageDialog [message #1602050 is a reply to message #1602049] Thu, 05 February 2015 04:37 Go to previous messageGo to next message
Yes, I imported the package BabelLanguagePack-rt.rap-de_4.2.0.v20130724060447.
Is there a default package or something like this?
Re: Localization of JFace MessageDialog [message #1602157 is a reply to message #1602050] Thu, 05 February 2015 06:02 Go to previous messageGo to next message
You might want try to import the rt.rap language pack into your target through the software site: http://download.eclipse.org/technology/babel/update-site/R0.12.1/luna.
You will have to include these features to your launcher.
Re: Localization of JFace MessageDialog [message #1602200 is a reply to message #1602157] Thu, 05 February 2015 06:37 Go to previous messageGo to next message
I imported the features ending with nl_en_AA, nl_en_AU and nl_en_CA. But the buttons are still shown in german.
Is there a nl_en feature? I think thats whats missing. Because my .properties files are not used until i created the _en.properties files.
I set the locale using RWT.setLocale(Locale.ENGLISH). Maybe there is the mistake?
Re: Localization of JFace MessageDialog [message #1602251 is a reply to message #1602200] Thu, 05 February 2015 07:19 Go to previous messageGo to next message
The only way changing the buttons text is the argument -nl en in the Run Configurations. I thought this would be dynamically, too.
So i solved it, but it is maybe not really fine.
Re: Localization of JFace MessageDialog [message #1602331 is a reply to message #1602251] Thu, 05 February 2015 08:33 Go to previous message
By the way I understand it and made it work is that the -nl argument defines what is the default Locale of your Application. You don't need that. Once you added the *nl_* fragments from Babel to your launch config, you can change the language by changing the language of your browser. I believe nothing else is necessary. Unfortunately, I never tried to change the Locale on the run through a widget.
Previous Topic:Row Template crashs in RAP Version 2.3.1
Next Topic:Table/List with custom row elements
Current Time: Sun Jul 20 14:23:30 EDT 2025
Powered by FUDForum. Page generated in 0.05246 seconds
