Home » Modeling » QVT-OML » Compilation errors found when running a transformation inside the jboss container
Compilation errors found when running a transformation inside the jboss container [message #1578652] |
Thu, 22 January 2015 09:35  |
Hello guys, i have a java class, with a main method, that runs a qvto transformation to transform my xmi in another model. Everything is working great! But i need to integrate the same code in a project web, so the user can click to call a action and download the new model. The problem here is that i have the same code running as a java application and running in the web server. The second one just fail without any precise information.
Following you can see the stack (but remember, theres no compilation error, because the transformation already works if i run as java application):
11:33:56,953 ERROR [STDERR] java.lang.Exception: Compilation errors found in unit 'file:/Users/buda/workspace/workspace_experimento/jboss-5.1.0.GA/server/default/tmp/5c4opy-rhrvsq-i588lxj3-1-i588mtsy-9p/workflow-ear.ear/QVTOTransformation.qvto'
11:33:56,954 ERROR [STDERR] at org.domain.dsl.JPDLDSLUtil.convertXMIToJPDL(JPDLDSLUtil.java:114)
11:33:56,954 ERROR [STDERR] at org.domain.workflow.session.WorkflowExecuter.deployWorkflows(WorkflowExecuter.java:78)
11:33:56,954 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
11:33:56,954 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
11:33:56,954 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
11:33:56,954 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:606)
11:33:56,954 ERROR [STDERR] at org.jboss.seam.util.Reflections.invoke(Reflections.java:22)
11:33:56,954 ERROR [STDERR] at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32)
11:33:56,954 ERROR [STDERR] at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56)
11:33:56,954 ERROR [STDERR] at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28)
11:33:56,954 ERROR [STDERR] at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.core.ConversationInterceptor.aroundInvoke(ConversationInterceptor.java:65)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.security.SecurityInterceptor.aroundInvoke(SecurityInterceptor.java:163)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:185)
11:33:56,955 ERROR [STDERR] at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:103)
11:33:56,955 ERROR [STDERR] at org.domain.workflow.session.WorkflowExecuter_$$_javassist_seam_8.deployWorkflows(WorkflowExecuter_$$_javassist_seam_8.java)
11:33:56,956 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
11:33:56,956 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
11:33:56,956 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
11:33:56,956 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:606)
11:33:56,956 ERROR [STDERR] at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:335)
11:33:56,956 ERROR [STDERR] at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:280)
11:33:56,956 ERROR [STDERR] at org.jboss.el.parser.AstMethodSuffix.getValue(AstMethodSuffix.java:59)
11:33:56,956 ERROR [STDERR] at org.jboss.el.parser.AstMethodSuffix.invoke(AstMethodSuffix.java:65)
11:33:56,956 ERROR [STDERR] at org.jboss.el.parser.AstValue.invoke(AstValue.java:96)
11:33:56,956 ERROR [STDERR] at org.jboss.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
11:33:56,956 ERROR [STDERR] at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
11:33:56,956 ERROR [STDERR] at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
11:33:56,956 ERROR [STDERR] at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
11:33:56,956 ERROR [STDERR] at javax.faces.component.UICommand.broadcast(UICommand.java:387)
11:33:56,956 ERROR [STDERR] at org.ajax4jsf.component.AjaxViewRoot.processEvents(AjaxViewRoot.java:329)
11:33:56,956 ERROR [STDERR] at org.ajax4jsf.component.AjaxViewRoot.broadcastEventsForPhase(AjaxViewRoot.java:304)
11:33:56,957 ERROR [STDERR] at org.ajax4jsf.component.AjaxViewRoot.processPhase(AjaxViewRoot.java:261)
11:33:56,957 ERROR [STDERR] at org.ajax4jsf.component.AjaxViewRoot.processApplication(AjaxViewRoot.java:474)
11:33:56,957 ERROR [STDERR] at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
11:33:56,957 ERROR [STDERR] at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
11:33:56,957 ERROR [STDERR] at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
11:33:56,957 ERROR [STDERR] at javax.faces.webapp.FacesServlet.service(FacesServlet.java:265)
11:33:56,957 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
11:33:56,957 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.web.IdentityFilter.doFilter(IdentityFilter.java:40)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.web.MultipartFilter.doFilter(MultipartFilter.java:86)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64)
11:33:56,957 ERROR [STDERR] at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45)
11:33:56,958 ERROR [STDERR] at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:206)
11:33:56,958 ERROR [STDERR] at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290)
11:33:56,958 ERROR [STDERR] at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:388)
11:33:56,958 ERROR [STDERR] at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:515)
11:33:56,958 ERROR [STDERR] at org.jboss.seam.web.Ajax4jsfFilter.doFilter(Ajax4jsfFilter.java:56)
11:33:56,958 ERROR [STDERR] at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
11:33:56,958 ERROR [STDERR] at org.jboss.seam.web.LoggingFilter.doFilter(LoggingFilter.java:60)
11:33:56,958 ERROR [STDERR] at org.jboss.seam.web.HotDeployFilter.doFilter(HotDeployFilter.java:53)
11:33:56,958 ERROR [STDERR] at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158)
11:33:56,958 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
11:33:56,958 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
11:33:56,958 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
11:33:56,959 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:433)
11:33:56,959 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
11:33:56,959 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
11:33:56,959 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
11:33:56,959 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
11:33:56,959 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
11:33:56,960 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
11:33:56,960 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
11:33:56,960 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
11:33:56,960 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
11:33:56,960 ERROR [STDERR] at java.lang.Thread.run(Thread.java:745)
Re: Compilation errors found when running a transformation inside the jboss container [message #1578851 is a reply to message #1578652] |
Thu, 22 January 2015 11:56   |
I can pretty much guarantee that there IS a compilation error.
Probably caused by a failure to configure the invocation context
appropriately.
Typically a model/metamodel will not be resolveable.
As a minimum I recommend that you start by providing a dialog in which
the compilation error is displayed with adequate detail.
Ed Willink
> application):
> found in unit
Current Time: Sat Jul 19 12:39:45 EDT 2025
Powered by FUDForum. Page generated in 0.25223 seconds
