Home » Eclipse Projects » EGit / JGit » EGit removing stale branches?
EGit removing stale branches? [message #1170243] Mon, 04 November 2013 09:00 Go to next message
I'm new to Git and just playing around with the tools trying this and that. I set up
a remote repo (R), cloned it twice to different locations (A,B), created a local
branch with A, pushed it to R, pulled it into B. Than I deleted the remote branch
via a push spec from A and R. So far so good. But than I realized that the changes
did not travel into B. I wasn't able to find an option to prune stale branches.
So, how can I remove stale remote branches with EGit? Using the (msys) CLI I can issue various commands like git fetch --prune or git remote prune origin.
Re: EGit removing stale branches? [message #1170666 is a reply to message #1170243] Mon, 04 November 2013 15:11 Go to previous messageGo to next message
I don't think prune is supported directly yet in EGit.
But supposedly JGit supports the gc.pruneExpire config parameter, and EGit definitely supports git gc (look in the right-click menu of entries in the Git Repositories view for that). So in theory you could do it that way. I've never tried it though.
Probably easier to to use the command-line, or a simple external launcher with the root of the currently selected clone as the working directory. Ordinarily You can get at the clone root with the variable ${git_work_tree}
Re: EGit removing stale branches? [message #1176659 is a reply to message #1170666] Fri, 08 November 2013 08:25 Go to previous messageGo to next message
This isn't yet implemented in EGit. GC does not delete any refs but only purges unreachable objects.
Re: EGit removing stale branches? [message #1576679 is a reply to message #1176659] Wed, 21 January 2015 08:04 Go to previous messageGo to next message
I stumbled over the same question today. From my experience it is still not supported.
Is there a bug for that?
Re: EGit removing stale branches? [message #1579289 is a reply to message #1576679] Thu, 22 January 2015 17:41 Go to previous message
I didn't find an enhancement bug requesting this feature
Previous Topic:Saving in merge tool causes endless blocking
Next Topic:Pushing, auth fail
Current Time: Sun Jul 20 18:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.04246 seconds
