Home » Modeling » EMF » Warning sign(My program is not working right I tried to get used to dialog boxes but my program doesn't do what I want it to do )
icon4.gif  Warning sign [message #1573676] Mon, 19 January 2015 17:02 Go to next message
//Basic Calculator
// January 13, 2015
// This program performs simple calculations
// //////////////////////////////////////////////////////////program without dialog boxes
import java.util.Scanner;
public class Basic_Calculator {
// create a Scanner Object
Scanner input = new Scanner(System.in);
int num1 = 0; // initialize number 1
int num2 = 0; // initialize number 2
int choice = 0; // initialize the number for the menu choice
double computanswer = 0; // initialize answer variable
double randomnumber; // initialize random number variable
Scanner input1 = new Scanner (System.in); // set up input Environment
// Set up your User menu
System.out.println("Menu choices: \n"+
"1. Add \n"+
"2. Subtract\n"+
"3. Multiply\n"+
"4. Divide\n"+
"5. Generate Random Number\n\n"+
"Please make a choice");
// collect user input
int userchoice = input1.nextInt(); // You have to create a second variable for the choice selection number on the input line
if (num1 > 5 || num1 < 1); // validate input
System.out.println("You have made an invalid selection"); // input validation message
System.out.println("Please choose a number between 1 and 5"); // This returns to the last line of the Menu
switch (userchoice) {
case 1:
System.out.println("Enter your first Number");
int choice1usernum1 = input1.nextInt(); // holds the first number the user puts in
System.out.println("Enter your second Number");
int usernum2 = input1.nextInt(); // holds the second number the user puts in
computanswer = num1 + num2; // answer to choice 1
System.out.println("Your Answer is "+computanswer);break; // converts the string to numbers
case 2:
int choice2usernum1 = input1.nextInt(); // holds the first number the user puts in
int choice2usernum2 = input1.nextInt(); // holds the second number the user puts in
computanswer = num1 - num2; // answer to choice 2
case 3:
int choice3usernum1 = input1.nextInt(); // holds the first number the user puts in
int choice3usernum2 = input1.nextInt(); // holds the second number the user puts in
computanswer = num1 * num2; // answer to choice 3
case 4:
int choice4usernum1 = input1.nextInt(); // holds the first number the user puts in
int choice4usernum2 = input1.nextInt(); // holds the second number the user puts in
computanswer = num1 / num2; // answer to choice 4
case 5:
// Generate 2 Random single-digit integers Numbers
int usernumb1 = (int)(Math.random() * 100);
int usernumb2 = (int)(Math.random() * 100);
// If number 1 < number 2 , swap number 1 with number 2
if (usernumb1 < usernumb2) {
int temp = usernumb1;
usernumb1 = usernumb2;
usernumb2 = temp;
}//switch
}//public static void
private static int randomnumber() {
return 0;
}//private static int
} //public class
Re: Warning sign [message #1574874 is a reply to message #1573676] Tue, 20 January 2015 08:44 Go to previous messageGo to next message
Michele,
There's no question in your post and the content does not appear to be
EMF related.
On 20/01/2015 2:22 PM, Michele Kinsella wrote:
> //Basic Calculator
> // January 13, 2015
> public static void main(String[] args) {
> number 1
> number 2
> int choice = 0; //
> Environment
> "1. Add \n"+
> "2. Subtract\n"+
> "3. Multiply\n"+
> "4. Divide\n"+
> line
> case 1:
> holds the first number the user puts in System.out.println("Enter your
> second Number");
> case 2:
> second Number");
> case 3: System.out.println("Enter
> second Number");
> answer to choice 3
> case 4: System.out.println("Enter your first
> Number");
> second Number");
> case 5:
> with number 2
> usernumb2 = temp;
> }//switch
> return 0;
> } //public class
Re: Warning sign [message #1574915 is a reply to message #1574874] Tue, 20 January 2015 09:14 Go to previous message
Perhaps http://stackoverflow.com/ would be a better place to get help with this.
Previous Topic:Generated extensions to Switch<T> are failing null analysis
Next Topic:[Xcore] calling super method from overridden method
Current Time: Sun Jul 20 18:53:06 EDT 2025
Powered by FUDForum. Page generated in 0.04631 seconds
