Home » Eclipse Projects » Eclipse Platform » Features & Fragments
Features & Fragments [message #156604] Thu, 13 November 2003 23:51 Go to next message
Originally posted by: dcorbin.machturtle.com
I have a plugin that requires a JNI library. Currently I have four
different fragemnts for four libraries on four different platforms. In
addition, I have a 3 other plugins (pure Java) that depend on the fragment,
and four features -- one for each platform containing the three pure
plugins and that platform-appropriate fragment.
The question is, what are the choices for having a single feature instead of
four? I imagine I could make one fragment supporting all four platforms,
though this seems a little wasteful.
Is there anyway to have a feature say "one of these four fragments depending
on the installing platform"?
David Corbin
Re: Features & Fragments [message #156613 is a reply to message #156604] Fri, 14 November 2003 01:25 Go to previous messageGo to next message
There is a thread called "Plugin packaging with platform dependent file"
posted earlier today that talks about this. For convenience I will
repost my reply though:
This is totally possible, open up your feature.xml in the manifest
editor and go to the content tab. There should be a list of the plugins
and fragments that you want to include in the feature. Put all of the
plugins/fragments from all platforms into here.
Let's say you have a plugin named foo. You then have two fragments
foo.linux and foo.windows. Right click on foo.linux and go to
properties. In the properties in the bottom select the correct
attributes such as x86, linux, gtk, etc.
Do the same for windows but select values such as x86, win32, win32, etc.
-Phil
> Thanks
> David Corbin
Re: Features & Fragments [message #156743 is a reply to message #156613] Fri, 14 November 2003 07:38 Go to previous messageGo to next message
> -Phil
Many thanks. I figured it had to be.
>> fragment, and four features -- one for each platform containing the three
>> pure plugins and that platform-appropriate fragment.
>> of
>> depending on the installing platform"?
>> Thanks
>> David Corbin
Re: Features & Fragments [message #159977 is a reply to message #156743] Fri, 21 November 2003 05:53 Go to previous messageGo to next message
>> -Phil
That worked well. Now, I've got to something similar, based on Eclipse
versions. But I don't see a way to make the fragment requirement based on
Eclipse version.
Thanks.
David
Re: Features & Fragments [message #160037 is a reply to message #159977] Fri, 21 November 2003 09:08 Go to previous messageGo to next message
> Eclipse version.
> Thanks.
> David
Require the eclipse feature's you need in your feature. Is there a
situation where you feel you need the fragment to target a specific
Eclipse version rather than the plugin of which it is a part of?
Peter
Re: Features & Fragments [message #160286 is a reply to message #160037] Fri, 21 November 2003 14:51 Go to previous message
>> on Eclipse version.
>> Thanks.
>> David
> Peter
Well, I don't have the specifics handy, but in Eclipse 3.0, APIs are being
broken. One solution to working with both 2.x and 3.0 is to use fragments
that match Eclipse versions. At the moment, I think I'm going to use
another solution, but it seems like a natural thing to want to do for me.
David
Previous Topic:Eclipse hangs with linux 2.6 test9
Next Topic:Installed Features
Current Time: Sat Jul 19 18:00:16 EDT 2025
Powered by FUDForum. Page generated in 0.03769 seconds
