Home » Eclipse Projects » NatTable » Multi edit in Menu options (Multi edit in Menu options )
Multi edit in Menu options [message #1565830] Thu, 15 January 2015 09:09 Go to next message
I have placed the Multi Edit on Menu options that we get when we right click on the column of the nat table.
It works correctly, my question is:
How shall I grey out the menu option for Multi edit on the basis of whether the cells are editable or not.
I have gone through the code of Nat Table and there is an iterator that calculates the cell Size
for (Iterator<ILayerCell> iterator = editCells.iterator(); iterator.hasNext(); ) {
ILayerCell layerCell = iterator.next();
LabelStack labelStack = layerCell.getConfigLabels();
IEditableRule editableRule = configRegistry.getConfigAttribute(
EditConfigAttributes.CELL_EDITABLE_RULE,
DisplayMode.EDIT, labelStack.getLabels());
if (!editableRule.isEditable(layerCell, configRegistry)) {
iterator.remove();
But the problem is how can I invoke this before pressing F2 or how can I get to know that the Multi Edit will not be invoked so that on right click I can grey out the Multi Edit option.
Ambuj
Re: Multi edit in Menu options [message #1565899 is a reply to message #1565830] Thu, 15 January 2015 09:56 Go to previous messageGo to next message
Hi Ambuj,
If you use NatTable IMenuItemProvider to add the multi-edit menu item to the menu, you can use the following code:
new IMenuItemProvider() {
   public void addMenuItem(NatTable natTable, Menu popupMenu) {
      final MenuItem myMenuItem = new MenuItem(popupMenu, SWT.PUSH);
      myMenuItem.setText("Some Text");
      myMenuItem.addSelectionListener(new SelectionAdapter() {
         public void widgetSelected(SelectionEvent event){
            //Do your stuff
      popupMenu.addMenuListener(new MenuAdapter() {
         public void menuShown(MenuEvent e) {
            myMenuItem.setEnabled(condition);
Hope it Helps
Re: Multi edit in Menu options [message #1565950 is a reply to message #1565899] Thu, 15 January 2015 10:30 Go to previous messageGo to next message
With the current version of NatTable the solution above is a way to solve your requirement.
With NatTable 1.2.0 you will be able to register an IMenuItemState to grey out or hide menu items.
Re: Multi edit in Menu options [message #1567136 is a reply to message #1565899] Fri, 16 January 2015 02:15 Go to previous message
Thanks Sheemesh and Dirk for providing the solution
[Updated on: Fri, 16 January 2015 02:28] by Moderator
Previous Topic:Editable NatTable for GlazedLists?
Next Topic:How to get live updates while maintaining a sorted tree
Current Time: Sun Jul 20 16:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.04506 seconds
