Home » Modeling » TMF (Xtext) » Xbase refactoring for static methods
Xbase refactoring for static methods [message #1563820] Wed, 14 January 2015 07:23 Go to next message
in my Xbase DSL I can define functions that are then inferred into
static methods of a Java class (I don't even need access to definitions
in other files, I don't have an import section, and there are no other
special features in this DSL). The name of the generated Java class is
computed using the file name (similar to the Scripting example of 7
languages):
val className =
"mypackage."+script.eResource.URI.trimFileExtension.lastSegment
Refactoring works correctly but if I refactor a function name, at the
end of the refactoring all references to that function are replaced with
the fully qualified name.
For example,
MyFile.mydsl
op foo() {
return foo();
becomes after refactoring
op foo() {
return mypackage.MyFile.foo();
which is fine, but ugly to look at ;)
what should I customize to avoid this?
I debugged a little, and I noted that
DefaultReferenceUpdater class
protected void createReferenceUpdate(IReferenceDescription
referenceDescription, URI referringResourceURI,
ElementRenameArguments elementRenameArguments, ResourceSet resourceSet,
IRefactoringUpdateAcceptor updateAcceptor) {
URI referringElementNewURI = elementRenameArguments
.getNewElementURI(referenceDescription.getSourceEObjectUri());
EObject referringElement =
resourceSet.getEObject(referringElementNewURI, false);
URI targetElementNewURI =
elementRenameArguments.getNewElementURI(referenceDescription.getTargetEObjectUri());
EObject newTargetElement = resourceSet.getEObject(targetElementNewURI,
false);
createReferenceUpdate(referringElement, referringResourceURI,
referenceDescription.getEReference(),
referenceDescription.getIndexInList(), newTargetElement,
updateAcceptor);
newTargetElement is already fully qualified...
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Xbase refactoring for static methods [message #1565298 is a reply to message #1563820] Thu, 15 January 2015 02:39 Go to previous messageGo to next message
Hi Lorenzo,
you may want to dig into
SerializerScopeProvider.getExecutableScope(XAbstractFeatureCall,
JvmIdentifiableElement) and see what's going wrong there.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: Xbase refactoring for static methods [message #1565587 is a reply to message #1565298] Thu, 15 January 2015 06:12 Go to previous messageGo to next message
On 15/01/2015 08:39, Sebastian Zarnekow wrote:
> Hi Lorenzo,
Hi Sebastian
thank you for the hint; I tried to debug that part, and everything seems
to work correctly (or at least, it looks like it behaves the same as
Xtend does for refactoring of static methods). Note that while
refactoring is triggered, and I type the new name, all references are
being updated correctly (i.e., not fully qualified) while I'm typing,
i.e., lively. The problem takes place when I press ENTER: the
references are then textually updated with the fully qualified name...
So the problem takes place somewhere else; during the debugging I can't
seem to find the exact place where the wrong behavior takes place... I
tried to debug until the refactoring unit of work terminates...
I also tried to add a custom QualifiedNameProvider so that
MyFile.mydsl
op foo() {
return foo();
the qualified name of foo() corresponds to the qualified name of the
inferred operation, mypackage.MyFile.foo, but this does not solve the
problem either...
thanks in advance
Lorenzo
Xtext Book:
Re: Xbase refactoring for static methods [message #1565640 is a reply to message #1565587] Thu, 15 January 2015 06:54 Go to previous messageGo to next message
Hi Lorenzo,
I take the scope that is produced by #getExecutableScope returns an
EObjectDescription for the method with the right name, e.g. the short
version?
Best,
Sebastian
Re: Xbase refactoring for static methods [message #1565672 is a reply to message #1565640] Thu, 15 January 2015 07:11 Go to previous messageGo to next message
On 15/01/2015 12:54, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> version?
Exactly: the EObjectDescription has the short name...
another funny symptom: as I said when I type in the editor references
are correctly updated (with the short name); if I do NOT press ENTER the
document stays modified correctly (short name); if I press ENTER the
document text is updated wrongly (fully qualified name). If instead of
ENTER, I open the rename dialog, the preview of the change shows the
final result with the wrong text (fully qualified name).
cheers
Lorenzo
Xtext Book:
Re: Xbase refactoring for static methods [message #1565681 is a reply to message #1565672] Thu, 15 January 2015 07:19 Go to previous messageGo to next message
OK, some updates: I can reproduce exactly the same problem with Xtend
(2.7.3) :(
package mypackage
class MyXtendFile {
def static void foo() {
foo()
start renaming foo to bar and then press ENTER, the resulting source
file is:
package mypackage
class MyXtendFile {
def static void bar() {
mypackage.MyXtendFile.bar()
I'm sorry I did not detect this before, but while debugging the focus on
the editor is lost and thus I did not try to press ENTER.
should I file a bug?
cheers
Lorenzo
Xtext Book:
Re: Xbase refactoring for static methods [message #1565906 is a reply to message #1565681] Thu, 15 January 2015 10:03 Go to previous messageGo to next message
The linked editing is just some search&replace trick. The actual
refactoring happens after <enter>.
Could you please file a ticket for this issue? Thanks!
Best,
Sebastian
Re: Xbase refactoring for static methods [message #1565978 is a reply to message #1565906] Thu, 15 January 2015 10:53 Go to previous message
> Best,
> Sebastian
Done, https://bugs.eclipse.org/bugs/show_bug.cgi?id=457617
I also added some additional findings (but I have no idea if they can
help :)
cheers
Lorenzo
Xtext Book:
Previous Topic:"Mark Occurrences" in EmbeddedXtextEditor
Next Topic:Parser for Column Based Programming Language
Current Time: Sun Jul 20 17:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.04127 seconds
