Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Client] running e3 demo with CDO repository
[EMF Client] running e3 demo with CDO repository [message #1469314] Tue, 11 November 2014 08:42 Go to next message
I have installed EMF client platform and i am testing e3 demo. When i try to add new repository then only provider option i have is EMFStore. I would like to run demo application with CDO repository.... any idea how should i proceed?
Re: [EMF Client] running e3 demo with CDO repository [message #1470277 is a reply to message #1469314] Wed, 12 November 2014 03:00 Go to previous messageGo to next message
you need to add the CDO provider to your run configuration.
Best regards
Jonas
Am 11.11.2014 14:42, schrieb ModelGeek Mising name:
> Cheers,
Re: [EMF Client] running e3 demo with CDO repository [message #1560395 is a reply to message #1470277] Mon, 12 January 2015 10:21 Go to previous messageGo to next message
thanks!
I am able to have CDO provider. If i try to select tcp provider and give host as localhost and port as 2036 and name as repo1 then when i try to open repo1 i get the following execption
org.eclipse.net4j.signal.RemoteException: org.eclipse.emf.cdo.server.RepositoryNotFoundException: Repository not found: null
at org.eclipse.emf.cdo.server.internal.net4j.protocol.OpenSessionIndication.responding(OpenSessionIndication.java:120)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:170)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:93)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:301)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:256)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:56)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:331)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
any idea why i am having this exception even when Server is up and running....
cheers
Re: [EMF Client] running e3 demo with CDO repository [message #1561624 is a reply to message #1560395] Tue, 13 January 2015 02:44 Go to previous messageGo to next message
have you validated somehow, that the CDO repository is there and the
repository is running on this port?
Best regards
Jonas
Am 12.01.2015 um 16:21 schrieb ModelGeek Mising name:
> thanks!
> found: null
> at
> at
> at
> at
> at
> at
> at
> at
> running....
> cheers
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Client] running e3 demo with CDO repository [message #1561877 is a reply to message #1561624] Tue, 13 January 2015 05:57 Go to previous messageGo to next message
I have tried to run the sample CDO client example and it runs properly with the same repository credentials but when i try ECP demo then i get the above shown exception....
I am running the MasterServer example for CDO
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
<repository name="repo1">
<property name="overrideUUID" value=""/>
<property name="supportingAudits" value="true"/>
<property name="supportingBranches" value="true"/>
<property name="ensureReferentialIntegrity" value="false"/>
<property name="allowInterruptRunningQueries" value="true"/>
<property name="idGenerationLocation" value="CLIENT"/> <!-- Possible values: STORE | CLIENT -->
<property name="serializeCommits" value="false"/>
<property name="optimisticLockingTimeout" value="10000"/>
Please check the image for adding repository dialog in ECP
connctory type: tcp
host : localhost
port: 2036
description :
Do you have any idea about my problem?
  • Attachment: ECPCDO.png
    (Size: 32.18KB, Downloaded 112 times)
Re: [EMF Client] running e3 demo with CDO repository [message #1563751 is a reply to message #1560395] Wed, 14 January 2015 06:28 Go to previous message
> thanks!
> found: null
That "null" at the end probably means that the CDO client (here: ECP/CDO Provider) has not sent the correct repository
name ("repo1")to the server.
I don't have the ECP sources at hand (nor do I have the time right now), but if you want to debug it, I would start by
setting a breakpoint on the client in the constructor of OpenSessionRequest.java and find out why the passed repository
name is null.
Cheers
/Eike
http://www.esc-net.de
> at
> at
> cheers
Previous Topic:[EMFForms] Additional model-specific services
Next Topic:[TENEO] Qualify entity name with package / PersistenceOptions.QUALIFY _ENTITY_NAME
Current Time: Sat Jul 19 11:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.07276 seconds
