Home » Language IDEs » ServerTools (WTP) » Adding custom TLD
Adding custom TLD [message #156031] Wed, 11 January 2006 22:47 Go to next message
Originally posted by: wul99.yahoo.com
I have a custom tag library customeTLD.tld in customTLD.jar. This jar file
is copied to WEB-INF/lib. how can i enable the tld so that code completion
in JSP editor can support the tld?
William
Re: Adding custom TLD [message #156047 is a reply to message #156031] Wed, 11 January 2006 23:46 Go to previous messageGo to next message
> file is copied to WEB-INF/lib. how can i enable the tld so that code
> completion in JSP editor can support the tld?
If customeTLD.tld has a URI defined within it using the "uri" tags
introduced in JSP 1.2, just declare your usage of the library with a
taglib directive and use that same uri in your JSP file. It
shouldn't be any more complicated than it would be just running it
on the server.
- Nitin
Re: Adding custom TLD [message #156069 is a reply to message #156047] Thu, 12 January 2006 04:19 Go to previous message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
I had to extract the tld from the jar file and place it directly in WEB-INF (or
a subdir) and point to this location in web.xml so that the wtp plugin could
reference it. But this is 0.7 knowledge and happened with the apache
implementation of the JSTL 1.1, maybe it has changed already.
Best regards
Wolfgang
> taglib directive and use that same uri in your JSP file. It shouldn't
> be any more complicated than it would be just running it on the server.
Previous Topic:could supply a tool to convent a project to J2EE prpject
Next Topic:How to change the context?
Current Time: Sun Jul 20 14:49:46 EDT 2025
Powered by FUDForum. Page generated in 0.05873 seconds
