Home » Archived » BIRT » Loosing Display Name in Output Columns
Loosing Display Name in Output Columns [message #1549455] Tue, 06 January 2015 09:42 Go to next message
Hi Guys,
Developers complains about custom display names are reset to factory Columns names in data set when they edit them (ie first changes are well saved, but furter edit will reset them).
Is anyone had this problem ? BIRT version is 2.5.1 with Remedy integration plugin (Remedy forms is used into Data Sets)
Re: Loosing Display Name in Output Columns [message #1551809 is a reply to message #1549455] Wed, 07 January 2015 16:18 Go to previous messageGo to next message
I believe I've heard of this issue before. Is there any way you could download the latest version of BIRT (4.4.1) and check if this is still an issue?
Re: Loosing Display Name in Output Columns [message #1560388 is a reply to message #1551809] Mon, 12 January 2015 10:17 Go to previous messageGo to next message
Michael Williams wrote on Wed, 07 January 2015 21:18
Hi Michael,
I try to use latest version but Remedy plugin seem to work only with 2.5.1 version !! BMC documentation also point on 2.5.1 Sad
Re: Loosing Display Name in Output Columns [message #1579623 is a reply to message #1560388] Thu, 22 January 2015 22:13 Go to previous message
What are the changes? Changes to the query?
Previous Topic:Web Viewer
Next Topic:Newspaper Layout with dynamic row height and grouping
Current Time: Sat Jul 19 19:47:02 EDT 2025
Powered by FUDForum. Page generated in 0.04762 seconds
