Home » Eclipse Projects » Eclipse Scout » Multi Column SmartField
Multi Column SmartField [message #1553263] Thu, 08 January 2015 10:55 Go to next message
Hello there
according to this blog entry and this wiki entry it's possible to provide a multi column smart field.
Now I was thinking of updating other form fields after a value from the smart field was selected.
Lets assume that the smart field has the following columns:
ID|Firstname|Lastname|Street|ZipCode|City
After selecting an entry I'd like to update the corresponding fields on the form. Namely the Firstname|Lastname|Street|ZipCode|City fields.
Is this possible?
Peter
Re: Multi Column SmartField [message #1553625 is a reply to message #1553263] Thu, 08 January 2015 15:33 Go to previous messageGo to next message
I love the questions on the forum where I learn something new about Scout. Wink
My instinct was telling me: NO, not possible. I was thinking that this is a limitation of the SmartField because you can only access the key of the LookupRow that is set as Value in the SmartField when the proposal Form is closed.
BUT I looked into the code and I discovered the getCurrentLookupRow() method. You can use it to access the LookupRow (and access the additionalRowData you are interested in):
protected void execChangedValue() throws ProcessingException {
  ILookupRow<Long> lookupRow = getCurrentLookupRow();
  PersonTableRowData additionalTableRowData = (PersonTableRowData) lookupRow.getAdditionalTableRowData();
  System.err.println(lookupRow.getText());
  System.err.println(lookupRow.getTooltipText());
  System.err.println(additionalTableRowData.getCity());
  System.err.println(additionalTableRowData.getBirthdate());
Please do not hesitate to share your findings about this method. I hope it works as I have told you.
Re: Multi Column SmartField [message #1554450 is a reply to message #1553625] Fri, 09 January 2015 02:44 Go to previous messageGo to next message
Hello Jeremie,
thanks for the hint. I'll have a look at it. But first I have to setup a multi column SQLLookup Service properly... somehow Smile
I''ll keep you posted
Peter
Re: Multi Column SmartField [message #1554593 is a reply to message #1554450] Fri, 09 January 2015 04:32 Go to previous message
Ok. It seems to work.
execChangeValue does the trick for retrieving the selected values.
In order to fill the multi column smart field with an SQLLookupService I overwrote the method in order to be able to access the other columsn fromt the SQL statement:
/* (non-Javadoc)
   * @see org.eclipse.scout.rt.server.services.lookup.AbstractSqlLookupService#execLoadLookupRows(java.lang.String, java.lang.String, org.eclipse.scout.rt.shared.services.lookup.ILookupCall)
  protected List<ILookupRow<Long>> execLoadLookupRows(String originalSql, String preprocessedSql, ILookupCall<Long> call) throws ProcessingException {
    Object[][] data = SQL.selectLimited(preprocessedSql, 1000, call);
    if (getConfiguredSortColumn() >= 0) {
      sortData(data, getConfiguredSortColumn());
    try {
      Class<?> genericsParameterClass = Object.class;
      try {
        genericsParameterClass = TypeCastUtility.getGenericsParameterClass(getClass(), ILookupService.class);
      catch (IllegalArgumentException e) {
        System.err.println("Unable to calculate type parameters for lookup service '" + getClass().getName() + "'. No key type validation will be performed.");
      List<ILookupRow<Long>> rows = createLookupRowArray(data, call, genericsParameterClass);
      int i = 0;
      for (ILookupRow<Long> row : rows) {
        CustomerCompleteTableRowData bean = new CustomerCompleteTableRowData();
        bean.setFirstname((String) data[i][1]);
        bean.setLastname((String) data[i][2]);
        bean.setCity((String) data[i][5]);
        bean.setStreet((String) data[i][3]);
        bean.setZip((String) data[i][4]);
        row.setAdditionalTableRowData(bean);
        i++;
      return rows;
      throw new ProcessingException("Unable to load lookup rows for lookup service '" + getClass().getName() + "'.", e);
I don't know if this is the most appropriate way to achieve a multi column smart field with DB backend or not. If not, please let me know. I'm eager to learn Smile
Peter
Previous Topic:How to update a tree in a tree field?
Next Topic:execAboutToShow()
Current Time: Sat Jul 19 12:48:13 EDT 2025
Powered by FUDForum. Page generated in 0.04262 seconds
