Combined parent-child property descriptors [message #155327] |
Sun, 24 October 2004 00:03  |
Originally posted by: ranjit.notMyId.com
Is there any way that I can combine parent class & child class
properties to be displayed on a property sheet?
Here is what I intend to do
Class A (parent)
prop1
prop2
Class B extends A
prop3
Class C extends A
prop4
Now what should I do such that whenever I click on a edit part
corresponding to model class B I get to see properties (1,2 & 3) in the
property sheet whereas see (1, 2 & 4) when I click C type item.
Right now I have to duplicate properties (1 & 2) in B and C.
I tried initializing the property descriptors in the constructors where
in the extended classes call the super() and then append their
respective properties to the propertyDescriptor array, but that doesn't
seem to work.
Thanks.
Re: Combined parent-child property descriptors [message #155340 is a reply to message #155332] |
Sun, 24 October 2004 10:52   |
Oops, sorry for posting it here and thanks for the solution :).
I think the mistake I was making was I directly tried to add the
properties of the child classes into the descriptors instead of making a
copy as in the snippet you posted.
Thanks.
Frank Dyck wrote:
> This should go to the platform group.
> You override the PropertyDescriptor related methods in the subclass and
> append the new properties to the old ones. Check the LED.java class in
> the logic example for an implementation of this.
> Examples:
> static{
> PropertyDescriptor pValueProp = new TextPropertyDescriptor(P_VALUE,
> LogicMessages.PropertyDescriptor_LED_Value);
> pValueProp.setValidator(LogicNumberCellEditorValidator.insta nce());
> if(descriptors!=null){
> newDescriptors = new
> IPropertyDescriptor[descriptors.length+1];//<<<<<<<<<
> for(int i=0;i<descriptors.length;i++)
> newDescriptors[i] = descriptors[i];// keep superclass
> properties
> newDescriptors[descriptors.length] = pValueProp; // append new one
> } else
> newDescriptors = new IPropertyDescriptor[]{pValueProp};
> public Object getPropertyValue(Object propName) {
> if (P_VALUE.equals(propName))
> return new Integer(getValue()).toString();
> if( ID_SIZE.equals(propName)){
> return new String("("+getSize().width+","+getSize().height+")");
> return super.getPropertyValue(propName);// <<<<<<<<<<<<<<<<<<<<<<<
> On Sun, 24 Oct 2004 00:03:37 -0400, Ranjit <ranjit@notMyId.com> wrote:
>> Hi,
>> Class A (parent)
>> prop1
>> prop2
>> Class B extends A
>> prop3
>> Class C extends A
>> prop4
>> the property sheet whereas see (1, 2 & 4) when I click C type item.
>> where in the extended classes call the super() and then append their
>> doesn't seem to work.
>> Thanks.
Re: Combined parent-child property descriptors [message #155348 is a reply to message #155340] |
Sun, 24 October 2004 11:04  |
Originally posted by: dyx.gmx.net
Don`t forget to do it also in the other Property related methods.
Check the LED class for the code.
> I think the mistake I was making was I directly tried to add the =
> properties of the child classes into the descriptors instead of making=
a =
> Thanks.
>> You override the PropertyDescriptor related methods in the subclass =
>> and append the new properties to the old ones. Check the LED.java =
>> class in the logic example for an implementation of this.
>> Examples:
>> static{
>> PropertyDescriptor pValueProp =3D new TextPropertyDescriptor(P_VA=
LUE,
>> pValueProp.setValidator(LogicNumberCellEditorValidator.insta nce()=
>> if(descriptors!=3Dnull){
>> newDescriptors =3D new =
>> for(int i=3D0;i<descriptors.length;i++)
>> newDescriptors[i] =3D descriptors[i];// keep superclass =
>> properties
>> newDescriptors[descriptors.length] =3D pValueProp; // append =
new =
>> one
>> } else
>> newDescriptors =3D new IPropertyDescriptor[]{pValueProp};
>> return new String("("+getSize().width+","+getSize().height+")=
>> return super.getPropertyValue(propName);// <<<<<<<<<<<<<<<<<<<<<<=
>> On Sun, 24 Oct 2004 00:03:37 -0400, Ranjit <ranjit@notMyId.com> =
>> wrote:
>>> Hi,
>>> Is there any way that I can combine parent class & child class =
>>> Class A (parent)
>>> prop1
>>> prop2
>>> Class B extends A
>>> prop3
>>> Class C extends A
>>> prop4
>>> Now what should I do such that whenever I click on a edit part =
>>> corresponding to model class B I get to see properties (1,2 & 3) in =
>>> the property sheet whereas see (1, 2 & 4) when I click C type item.=
>>> I tried initializing the property descriptors in the constructors =
>>> where in the extended classes call the super() and then append thei=
r =
>>> respective properties to the propertyDescriptor array, but that =
>>> Thanks.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
FUDForum. Page generated in 0.04064 seconds
