Home » Eclipse Projects » e(fx)clipse » Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app
Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1540720] Thu, 01 January 2015 12:38 Go to next message
I've followed the several e(fx)clipse tutorials to create my own OSGi based JavaFX app. I have experience creating Eclipse IDE plugins, but not so much exporting them into a stand-alone OSGi app, and I certainly wouldn't want to claim expert status on OSGi development.
When I export the product the build process fails with:
(app.feature.feature.group 1.0.0.201501011827) requires 'org.eclipse.fx.osgi.util 0.0.0' but it could not be found
 Cannot satisfy dependency:
(yes, it ends with the last 'cannot satisfy dependency').
The target runtime was created according to the tutorial, with a blank runtime located at ...../efxclipse/runtime-released/1.0.0/site.
Obviously I'm missing some lines to connect the dots, but which....
Onno.
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1542606 is a reply to message #1540720] Fri, 02 January 2015 14:19 Go to previous messageGo to next message
Looks like the feature generated does not include
"org.eclipse.fx.osgi.util" which tutorial did you take?
It looks like a bug in the wizard who generates the feature
Tom
> Thanks, Onno.
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1542632 is a reply to message #1542606] Fri, 02 January 2015 14:35 Go to previous messageGo to next message
Could you please use the 1.1.0 release? I just tried the nigthly build
and things work just fine.
Tom
> Tom
>> Thanks, Onno.
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1543846 is a reply to message #1542632] Sat, 03 January 2015 07:13 Go to previous messageGo to next message
Tom,
Ok, I'll try. My environment was based on tutorial step 4 where a target was defined. I noticed that when I resolved (several) missing dependencies that there were different versions of the same plugins I could choose from. Also, it seems that the local plugins I added in the target's definition (ControlsFX) couldn't be added to the feature.
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1544576 is a reply to message #1543846] Sat, 03 January 2015 17:04 Go to previous messageGo to next message
Just updated all tooling to 1.1.0 and started out with a clean, new project. Added no source or anything else and tried to export that.
However got the same kind of problem:
 Missing requirement: Eclipse DI integration for JavaFX 1.1.0.201411050703 (org.eclipse.fx.ui.di 1.1.0.201411050703) requires 'bundle org.eclipse.fx.core.di.context 1.1.0' but it could not be found
The target I created comes from the 'runtime-released/1.1.0' site, the ' Target Platform Feature'.
I'm trying to create an OSGi application, not so much an E4 application.
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1546252 is a reply to message #1544576] Sun, 04 January 2015 15:46 Go to previous messageGo to next message
Just Update the generated feature
Re: Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app [message #1551632 is a reply to message #1546252] Wed, 07 January 2015 13:55 Go to previous message
I'll update and will let you know soon! Thanks.
Previous Topic:Setup to include for @ContextValue annotation
Next Topic:org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error
Current Time: Sat Jul 19 20:51:22 EDT 2025
Powered by FUDForum. Page generated in 0.04368 seconds
