Home » Eclipse Projects » GEF » Using property Sheet
Using property Sheet [message #153986] Thu, 14 October 2004 03:26 Go to next message
Originally posted by: ranjit.notMyId.com
Is there a small example which would help me understand how to use a
property sheet for models?
All the tutorials talk about it but none have a bit of code or
explanation on the working.
Re: Using property Sheet [message #153996 is a reply to message #153986] Thu, 14 October 2004 05:07 Go to previous messageGo to next message
Sorry for a bit ambiguous question.
I thought I would correct myself before any replies.
I wanted to know if there was a way that the property sheets could be
populated with a specific data and the change getting reflected in the
view if the particular view item is selected.
e.g. creating a drop down of possible/allowable values (amy be taken
from information from other models).
Re: Using property Sheet [message #154004 is a reply to message #153996] Thu, 14 October 2004 09:27 Go to previous messageGo to next message
It should be pretty simple. Just return a descriptor which populates hte
celleditor with the choices you want. There is a propertysheet example by
the platform team/
You might want to check out EMF. I know that an EAttribute has a Type
attribute of EClass. They may allow you to choose from declared types in
your metamodel.
This is a model question. GEF doesn't know anything about a given
application's model.
"Ranjit" <ranjit@notMyId.com> wrote in message
news:cklf8l$rng$1@eclipse.org...
> Thanks
Re: Using property Sheet [message #154027 is a reply to message #154004] Thu, 14 October 2004 10:13 Go to previous messageGo to next message
> the platform team/
> your metamodel.
Hi Andy,
Thanks for the help, I would look into the example you mentioned.
But now I am a bit confused.
If the property sheet is not handled by the GEF how come I can change
the model by clicking on the view corresponding to it and then changing
the values in the property sheet. I thought that the property sheet
changes too are handled by the GEF part and passed on to the model.
Would I be correct to say the following with the working of the
propertySheets?
when a particular view object is selected on the canvas corresponding
Edit part gets the PropertyDescriptors for the model and shows them in
the property sheet. Any changes done to the values are directly sent to
the model via the setPropertyValue method. The model then can make sure
that the changes get back to the view using the fireProperty calls.
- Ranjit
>>Thanks
Re: Using property Sheet [message #154042 is a reply to message #154027] Thu, 14 October 2004 11:40 Go to previous messageGo to next message
> propertySheets?
No, the EditPart checks to see if either it or the model implements
IPropertySource. Generally, the model will implement IPropertySource, and
from that point on the property sheet is not dealing with anything in GEF.
Re: Using property Sheet [message #154050 is a reply to message #154042] Thu, 14 October 2004 11:53 Go to previous message
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ckm6b6$chl$1@eclipse.org...
>> propertySheets?
Thanks Randy, that clears all my doubts.
Also, that solves a big problem I had :).
Previous Topic:MidpointLocator and scrollbar
Next Topic:Image on Tool Bar
Current Time: Sat Jul 19 13:46:09 EDT 2025
Powered by FUDForum. Page generated in 0.04809 seconds
