Home » Newcomers » Newcomers » OSGI Services... LogReaderService ...
OSGI Services... LogReaderService ... [message #153053] Wed, 17 May 2006 18:30 Go to next message
Originally posted by: mgervais.signaturegenetics.com
I'm developping an rcp application. I've several questions:
-When I run my product, the org.eclipse.osgi framework is launch, if I
understand correctly it's the implementation of the OSGI specifications?
-How can I access to services of the framework? For example I want to get
the LogReaderService, which should be started with the framework? But I
don't konw if this interface is implemented in equinox... If not how can I
do it and register this service?
Thanks for you help, if you have some samples it would be apreciated...
Mickael
Re: OSGI Services... LogReaderService ... [message #153080 is a reply to message #153053] Thu, 18 May 2006 04:05 Go to previous messageGo to next message
Originally posted by: neil.integility.com
Gervais,
- Yes, "org.eclipse.osgi" is the system bundle that implements the
framework.
- Services of the framework are accessed the same as any other services
(because they ARE the same). The nicest way to do this is with Declarative
Services. The lower-level way is to use a ServiceTracker, eg:
ServiceTracker logReaderTracker = new ServiceTracker(context,
LogReaderService.class.getName(), null);
logReaderTracker.open();
// Later...
LogReaderService logReader = (LogReaderService)
logReaderTracker.getService();
if(logReader != null) {
// Do something with logReader
// Later still...
logReaderTracker.close();
- LogService and LogReaderService are implemented in Equinox by the
"org.eclipse.equinox.log" bundle. If you start that bundle, then you will
get a LogService and a LogReaderService that you can use. If you don't,
then you won't.
Kind regards
Neil Bartlett
Gervais Mickael wrote:
> Mickael
Re: OSGI Services... LogReaderService ... [message #153153 is a reply to message #153053] Thu, 18 May 2006 07:22 Go to previous messageGo to next message
And check out http://www.eclipse.org/equinox/bundles for a list of some
services that have been implemented.
Later,
PW
Re: OSGI Services... LogReaderService ... [message #153161 is a reply to message #153080] Thu, 18 May 2006 10:17 Go to previous messageGo to next message
Thanks for your help,
it has been very helpfull for me. I'm trying to add the bundle
org.eclipse.equinox.log to my product by it's not in the list, maybe it's
due to I'm using Eclipse 3.2...
Miclael
"Neil Bartlett" <neil@integility.com> wrote in message
news:fe14d0978e0748c8b84412e4e76a0b95$1@www.eclipse.org...
> Gervais,
> framework.
> // Later...
> // Later still...
> then you won't.
> Kind regards
> Neil Bartlett
>> Hi,
>> I do it and register this service?
>> Mickael
Re: OSGI Services... LogReaderService ... [message #153178 is a reply to message #153153] Thu, 18 May 2006 10:28 Go to previous message
Thanks again.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:e4hlfk$6do$2@utils.eclipse.org...
> Later,
> PW
Previous Topic:Where to find out if this environment is right for me.
Next Topic:Couple of questions
Current Time: Sat Jul 19 06:16:54 EDT 2025
Powered by FUDForum. Page generated in 0.09200 seconds
