Home » Eclipse Projects » GEF » collapse/expand nested container problem
collapse/expand nested container problem [message #151993] Fri, 24 September 2004 18:39 Go to next message
Originally posted by: zenilnh.infotech.stph.net
Hi All,
I have a problem,already discussed in message
http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6060.html.
The problem is stated verbatim from that message:
I want to allow the application users to create scrolled containers which
can contain several nodes.The users can create connections beetween the
nodes, which can be in the
same container or in different containers.
The users can collapse/extand the containers.
When a user collapse a container, all his children (nodes) are invisible.
I have overridden the method getModelChildren() in my ContainerEditPart,
where I return an
empty list.
1 - When the user collapse a container that contain a source node, the
node is not "visible",
and the connection towards a node in another container begin into space !
I want this connection to begin on the border of my container.
2 - When the user collapse a container that contain a TARGET node, the
and the connection that begin on a node in another container finish into
space !
I want this connection to finish on the border of my container.
3 - If both containers are collapsed, I want the connection to begin on
the border of the first one
, and to finish on the border of the second.
I understand the solution discussed, but it seems like a roundabout way of
doing things..
Whenver i collapse a container,got to remove all its children( and also all
the connections each of the child may have to elements in another
container).And then recalculate these connections and draw it between the
collapsed container to other containers.
Wheneve i expand a container,i got to add all its children back,remove all
conncetions,recalculte connections wrt the children
and draw it again. Doesnt this slow things down and (maybe) cause some
flickering?? Isn't there a better way of doing it??
I consider my composite figure something like a Tree wrapped in a
TreeViewer?? When i collapse a Tree,does the TreeViewer remove all the
items??
When i expand it back,does TreeViewer recreate all the items??I dont think
it does..So the TreeViewer/Tree is able to "maintain" the effect of
expansion/collapsion without actually modifying its children.. Is something
similar possible here??
If i can do something like a TreeViewer for my CompositeFigure,then i dont
have to worry about uncessearily managing its children,and all i have to
think about is recaculating connections[for which i dont think there is any
shortcuts..]
I may be wrong in my assumptions.. Can anyone clarify??
Zenil
Re: collapse/expand nested container problem [message #152219 is a reply to message #151993] Mon, 27 September 2004 16:24 Go to previous messageGo to next message
This is probably the easiest way to do it. You should just try it and
address performance issues as the come up.
"Certive" <zenilnh@infotech.stph.net> wrote in message
news:cj27m1$g07$1@eclipse.org...
> Hi All,
> where I return an
> empty list.
> space !
> doing things..
all
> items??
something
any
> shortcuts..]
> Thanks
> Zenil
Re: collapse/expand nested container problem [message #152230 is a reply to message #152219] Mon, 27 September 2004 19:10 Go to previous message
Hi Randy,
Thanks for the answer.I will start doing it this way.As you said it
seems the best way.
Rgds,
Zenil
> > Hi All,
> > where I return an
> > empty list.
> > space !
> > doing things..
> all
> > items??
> something
> any
> > shortcuts..]
> > Thanks
> > Zenil
Previous Topic:Sharing zoom action between different editors
Next Topic:Does GEF support a hierarchical layout of nested subgraphs?
Current Time: Sat Jul 19 10:58:33 EDT 2025
Powered by FUDForum. Page generated in 0.03740 seconds
