Debug servlet with Tomcat require restart after each modification [message #151839] |
Wed, 14 December 2005 02:12  |
Originally posted by: whisk_whisk.yahoo.com
Hi all,
I am now using the eclipse 3.1.1, WTP 1.0RC4, and Tomcat 5.0 as my
development platform.
The Tomcat is started in debug mode and all break points are stopped
successfully.
However, everytime I have modified a servlet, even just adding a blank
space, triggers a restart of the Tomcat server.
What I expect is the hotswap of the classes with no structual change. How
should I configure the Eclipse and Tomcat to achieve this?
Thank you very much for your help!
Best wishes,
WHiSK
Re: Debug servlet with Tomcat require restart after each modification [message #152252 is a reply to message #151839] |
Wed, 14 December 2005 07:48   |
Originally posted by: dserodio.gmail.com
WHiSK wrote:
> Hi all,
> successfully.
> How should I configure the Eclipse and Tomcat to achieve this?
I expect that too, if the "Tomcat Plugin" can do it, why can't WTP?
TIA,
Daniel Serodio
Re: Debug servlet with Tomcat require restart after each modification [message #152317 is a reply to message #152252] |
Wed, 14 December 2005 11:05   |
Daniel Serodio wrote:
> WHiSK wrote:
>> Hi all,
>> successfully.
> TIA,
> Daniel Serodio
This is really strange! Is there any config trick to make hotswap
possible?
I prefer a simple startup rather than those complicated remote debugging.
Re: Debug servlet with Tomcat require restart after each modification [message #152673 is a reply to message #152648] |
Sat, 17 December 2005 01:03  |
Darryl L. Miles wrote:
> WHiSK wrote:
>> or we can simple double click on the Server->Server
>> Configuration->Modules->Edit->Untick Auto Reloading Enabled
> You know I have completely forgotten that "Modules" tab exists. There
> was another query open for changing the Context path for a WebModule.
> This looks like the place in UI that should do the trick.
> Darryl
Yup~ exactly! but that tab can easily be ignored. the tab size should be
made bigger! it is toooo small now, i noticed it just by luck. >_<
happy programming!
FUDForum. Page generated in 0.07509 seconds
