Home » Eclipse Projects » GEF » About running logic-example3.0.0 as run-time workbench
About running logic-example3.0.0 as run-time workbench [message #151715] Wed, 22 September 2004 13:52 Go to next message
Hello ,
I am having eclipse 3.0 and GEFsdk 3.0. and logicexample 3.0
I created project and and src of it as source of logic example.
and plugin.xml , classpath etc. of this project from logic example plugin
itself.
there is no error in project but i receive yellow flag that
this method is deprecated. eg. IWOrkbench.UNDO deprecated.
so it doesnt run as run - time workbench.
so can you please tell me solution to run it as run time workbench
,as soon as possible.
Also tell me is there any wrong version that i am usinh ?
Re: About running logic-example3.0.0 as run-time workbench [message #151759 is a reply to message #151715] Wed, 22 September 2004 18:20 Go to previous messageGo to next message
DId you use Import-->Existing Plugins, to import the logic example?
Deprecation warning do not prevent compilation and should not affect your
ability to run the example. You need to use the wizard to create a file.
"mithun ruikar" <mithunruikar@yahoo.com> wrote in message
news:cise59$gc4$1@eclipse.org...
> Hello ,
> itself.
I'm trying this, but doesn`t run [message #151842 is a reply to message #151759] Thu, 23 September 2004 11:50 Go to previous messageGo to next message
Originally posted by: jdelgad.fedro.ugr.es
Hi !!!
I am also trying to run logic-example and I have used the steps that Randy
Hudson wrote, but I can`t find Import-->Existing Plugins, it doesn`t
appear. the options that appear in "Import..." are:
- Checkout projects from CVS
- Existing Ant BuildFile
- Existing project into WorkSpace
- External Features
- External Plugins and Fragments
- File System
- Team project set
- Zip file
I have tried with "Existing project into Workspace" and with "External
Plugins and Fragments", but it doesn`t run at all.
Please, I need your help as soon as posible. Thank you very much
> > Hello ,
> > itself.
Re: About running logic-example3.0.0 as run-time workbench [message #151850 is a reply to message #151759] Thu, 23 September 2004 14:41 Go to previous messageGo to next message
Hello ,
Randy told me about import from existing plugin option but i couldnt found
it. Also deprecation warnings are matters to me because when i run this
example as runtime workbench , and tried to make new file from file
creation wizard , creation window neither closed nor new file .logic is
created in selected project , when clicked on finish button.
when i saw .log file of this workspace i see there error :
exceptionInitializerError : at getInitialContents() of FileCreationPage1
class.
Also when tried other way , that to create new file manually by new -> file
of .logic extension it gave same error exceptionInitializerError and
noClassDefFoundError : but this time : at LogicEditor <init>.
i think this is complete descrioption of what i stucking with .
So Please give me solution of These "Deprecated" Warning.
> > Hello ,
> > itself.
Re: About running logic-example3.0.0 as run-time workbench [message #151866 is a reply to message #151850] Thu, 23 September 2004 16:27 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
Firstly, as Randy has already said, the depreciation warning messages
you are seeing are just warning messages..... they are not errors and
they are not what is causing your problems..... so just forget about them.
Perhaps if you attached a portion ( or all ) of each stack trace from
the .log file for the two errors you mentioned then it would be a little
easier to see what the problem was.
Guy
mithun ruikar wrote:
> Hello ,
> class.
>>>Hello ,
>>>itself.
Re: I'm trying this, but doesn`t run [message #153251 is a reply to message #151842] Thu, 07 October 2004 10:24 Go to previous message
Originally posted by: dyx.gmx.net
Open the Plugins View (Window->Show View -> Plugins) and right click on =
the plugin in there.
On Thu, 23 Sep 2004 15:50:47 +0000 (UTC), Jose <jdelgad@fedro.ugr.es> =
wrote:
> Hi !!!
> I am also trying to run logic-example and I have used the steps that =
> Randy
> - External Features
> - File System
> - Team project set
> - Zip file
> I have tried with "Existing project into Workspace" and with "External=
>> Deprecation warning do not prevent compilation and should not affect =
>> your
>> ability to run the example. You need to use the wizard to create a =
>> file.
>> > Hello ,
>> > and plugin.xml , classpath etc. of this project from logic example =
>> plugin
>> > itself.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Previous Topic:Container Question
Next Topic:Composite edit part - main/child editor level
Current Time: Sat Jul 19 11:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
