Home » Eclipse Projects » GEF » "Hide" Option in ContextMenu
"Hide" Option in ContextMenu [message #150775] |
Tue, 14 September 2004 03:01  |
Originally posted by: amitsaxena.iopsis.com
I m using the GEF Plugin and using the Shape plugin of gef that is
defiend in CVS of GEF.
On right click of any diagram, the context menu shows options of Undo, Redo,
Delete and etc.
I wanted the Functionality of "Hide" added to the context menu when right
clicked on any diagram which will hide that particular diagram and also the
"View" that will show the hidden diagram when clicked on view context menu.
Can u provide any directions or sample of how to proceed further??
Re: "Hide" Option in ContextMenu [message #150897 is a reply to message #150829] |
Wed, 15 September 2004 08:00   |
I want to Hide the Figures that r drawn on editor, not the palete
one. The Logic example hides the palete diagrams. Suppose, I drag a figure
and on the right click that figure on the editor , a menu of "Hide" should
appear and when clicked on that the figure should hide (some icon should
come on Palete when Hide is clicked on any figure in the editor).
Can u provide any sample of that ???
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:ci7910$9ll$1@eclipse.org...
> Add a property to your model that would indicate whether or not it's
hidden.
> The parent editpart should only return visible children in its
> getModelChildren() method.
> Add the Hide action in your ContextMenuProvider. The action should change
> the hidden state. When the child's editpart gets notified of this change,
> it should tell its parent to refreshChildren() (or rather,
add/removeChild()
> for better performance).
> How do you intend to allow the user to show hidden parts?
> You can look at the palette as an example. Right-click on the logic
palette
> and select "Customize." It has a hide checkbox which does the same thing.
> The implementation is slightly different in that the parent editpart
listens
> for changes to all its children, and refreshes itself when the hide
property
> changes on any of them. Related classes: PaletteEditPart, PaletteEntry.
> "Amit Saxena" <amitsaxena@iopsis.com> wrote in message
> news:ci645e$vn8$1@eclipse.org...
> > Hi,
> Redo,
> > Delete and etc.
right
> the
> menu.
Re: "Hide" Option in ContextMenu [message #150912 is a reply to message #150897] |
Wed, 15 September 2004 10:58   |
Yes, the palette. The palette is a graphical viewer driven by a model just
like your main graphical viewer.
news:ci9a1r$c7c$1@eclipse.org...
> Hello,
> hidden.
change
change,
> add/removeChild()
> palette
thing.
> listens
> property
> > > Hi,
is
> > Redo,
> > > Delete and etc.
> right
also
> > the
> > menu.
Re: "Hide" Option in ContextMenu [message #151210 is a reply to message #150912] |
Thu, 16 September 2004 07:20   |
I have this method that contains context menu .. When we right
click on any diagram on the editor , not on the Palete.
We get the option of Undo, Redo and Delete by the following code.
But the GEFActionConstants() does not contains "Hide" field in the
GEF API ...
It contains all fields except the "Hide" field.
I wanted the Hide option in the context menu with "Hide" and
"View" as option.
When Clicked on Hide option, it should hide that particular
diagram and
when clicked on View option, the diagram shown be visible.
And wht Methods to write in GEF for the above following ??
Can u modify the code for "Hide " and "View "??
public void buildContextMenu(IMenuManager menu)
// Add standard action groups to the menu
GEFActionConstants.addStandardActionGroups(menu);
// Add actions to the menu
menu.appendToGroup(
GEFActionConstants.GROUP_UNDO, // target group id
getAction(ActionFactory.UNDO.getId())); // action to add
menu.appendToGroup(
getAction(ActionFactory.REDO.getId()));
menu.appendToGroup(
GEFActionConstants.GROUP_EDIT,
getAction(ActionFactory.DELETE.getId()));
And Provide some sample or direction of how to proceed further??
news:ci9l3e$3p3$1@eclipse.org...
just
> > Hello,
palete
figure
should
> > hidden.
> change
> change,
> > add/removeChild()
> > palette
> thing.
> > listens
> > property
PaletteEntry.
> > > > Hi,
> is
Undo,
> > > Redo,
> > > > Delete and etc.
> > right
> also
> > > the
context
> > > menu.
Re: "Hide" Option in ContextMenu [message #151247 is a reply to message #151210] |
Thu, 16 September 2004 11:02   |
You need to create your own constants, actions, and request types, and the
commands to hide and show your model objects.
news:cibs2q$h1k$1@eclipse.org...
> Hello,
the
> GEF API ...
> "View" as option.
> diagram and
> menu.appendToGroup(
> menu.appendToGroup(
> menu.appendToGroup(
> just
> > > Hello,
> palete
> figure
> should
should
> > > hidden.
> > change
> > change,
> > > add/removeChild()
> > > palette
> > thing.
> > > listens
> > > property
> PaletteEntry.
> > > > > Hi,
that
> > is
> Undo,
> > > > Redo,
> > > > > Delete and etc.
when
> > > right
> > also
> > > > the
> context
> > > > menu.
Re: "Hide" Option in ContextMenu [message #151396 is a reply to message #151247] |
Mon, 20 September 2004 02:19   |
Can u provide any examples regarding the below question of creating
constants,actions and request types to hide the figure from the editor ..
Or Provide any samples ??
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cic9n3$dhv$1@eclipse.org...
> > Hello,
code.
> the
> > GEF API ...
> > "View" as option.
> > diagram and
> > menu.appendToGroup(
> > menu.appendToGroup(
> > menu.appendToGroup(
> > just
> > > > Hello,
> > palete
> > figure
> > should
> should
it's
> > > > hidden.
should
> > > change
> > > change,
> > > > add/removeChild()
logic
> > > > palette
same
> > > thing.
editpart
> > > > listens
hide
> > > > property
> > PaletteEntry.
> > > > > > Hi,
> that
> > > is
> > Undo,
> > > > > Redo,
> > > > > > Delete and etc.
> when
> > > > right
and
> > > also
> > > > > the
> > context
> > > > > menu.
further??
Re: "Hide" Option in ContextMenu [message #151669 is a reply to message #151396] |
Wed, 22 September 2004 01:05   |
Can u provide any examples or sample code for hiding of figures when click
"hide " from the context menu ..
news:cilsgm$8fu$1@eclipse.org...
the
> > > Hello,
right
> code.
in
> > the
> > > GEF API ...
> > > "View" as option.
> > > diagram and
> > > menu.appendToGroup(
> > > menu.appendToGroup(
> > > menu.appendToGroup(
model
> > > just
> > > > > Hello,
the
> > > palete
a
> > > figure
"Hide"
> > > should
> > should
> it's
> > > > > hidden.
> should
> > > > change
this
> > > > change,
> > > > > add/removeChild()
> logic
> > > > > palette
> same
> > > > thing.
> editpart
> > > > > listens
> hide
> > > > > property
> > > PaletteEntry.
> > > > > > > Hi,
gef
> > that
> > > > is
of
> > > Undo,
> > > > > > Redo,
> > > > > > > Delete and etc.
> > when
> > > > > right
> and
> > > > also
> > > > > > the
> > > context
> > > > > > menu.
> further??
Re: "Hide" Option in ContextMenu [message #151684 is a reply to message #151669] |
Wed, 22 September 2004 10:13   |
See the INCREMENT action in the logic example, and its associated constants
and model operations.
news:cir0ue$fml$1@eclipse.org...
> the
> > > > Hello,
> right
> > code.
field
> in
> > > the
> > > > GEF API ...
and
> > > > "View" as option.
particular
> > > > diagram and
visible.
> > > > menu.appendToGroup(
> > > > menu.appendToGroup(
> > > > menu.appendToGroup(
> model
> > > > just
> > > > > > Hello,
> the
> > > > palete
drag
> a
> > > > figure
> "Hide"
> > > > should
icon
> > > should
editor).
not
> > it's
> > > > > > hidden.
> > should
> > > > > change
> this
> > > > > change,
> > > > > > add/removeChild()
> > logic
> > > > > > palette
> > same
> > > > > thing.
> > editpart
> > > > > > listens
> > hide
> > > > > > property
> > > > PaletteEntry.
> > > > > > > > Hi,
> gef
> > > that
> > > > > is
options
> of
> > > > Undo,
> > > > > > > Redo,
> > > > > > > > Delete and etc.
menu
> > > when
> > > > > > right
diagram
> > and
> > > > > also
> > > > > > > the
view
> > > > context
> > > > > > > menu.
> > further??
Re: "Hide" Option in ContextMenu [message #152363 is a reply to message #151684] |
Wed, 29 September 2004 07:44  |
I m not getting the exact flow of how to procedd.. i have also
checked the Logic Part ...But it is too vast to ge the flow of Logic...
Can u provide any small example which contains the Hiding of diagrams on
context menu ..
Or Provide me the direction of how to proceed ??
news:cis11g$ieg$1@eclipse.org...
constants
click
and
> > the
> > > > > Hello,
> > right
following
> > > code.
> field
> > in
> > > > the
> > > > > GEF API ...
> and
> > > > > "View" as option.
> particular
> > > > > diagram and
> visible.
> > > > > menu.appendToGroup(
> > > > > menu.appendToGroup(
> > > > > menu.appendToGroup(
> > model
> > > > > just
> > > > > > > Hello,
not
> > the
> > > > > palete
> drag
> > a
> > > > > figure
> > "Hide"
> > > > > should
> icon
> > > > should
> editor).
> not
> > > it's
> > > > > > > hidden.
its
> > > should
> > > > > > change
of
> > this
> > > > > > change,
> > > > > > > add/removeChild()
the
> > > logic
> > > > > > > palette
the
> > > same
> > > > > > thing.
> > > editpart
> > > > > > > listens
the
> > > hide
> > > > > > > property
> > > > > PaletteEntry.
> > > > > > > > > Hi,
of
> > gef
> > > > that
> > > > > > is
> options
> > of
> > > > > Undo,
> > > > > > > > Redo,
> > > > > > > > > Delete and etc.
> menu
> > > > when
> > > > > > > right
> diagram
> > > and
> > > > > > also
> > > > > > > > the
> view
> > > > > context
> > > > > > > > menu.
> > > further??
Current Time: Sun Jul 20 15:36:39 EDT 2025
Powered by FUDForum. Page generated in 0.05510 seconds
