Home » Eclipse Projects » OM2M » Using CoAP based applications (Copper vs Erbium)
icon14.gif  Using CoAP based applications (Copper vs Erbium) [message #1464204] Fri, 07 November 2014 04:43 Go to next message
Hey guys,
First of all much thanks for your hard work. OM2M is a great work.
I was trying to set up a test environment with a CoAP (Erbium) running sensor DA. The problem I have is, I can not successfully pass the Authentication (requestingEntity). While using Copper plugin as CoAP client, I can send a GET request like,
coap :// [2001:bbbb:dddd:0:2ff:ffff:ffff:ffff]<colon>5683/om2m/nscl?authorization=admin:admin
and it works fine. But with Erbium the same request would respond with error like,
osgi> Nov 06, 2014 6:16:45 PM org.eclipse.om2m.core.router.Router doRequest
INFORMATION: RequestIndication [method=RETRIEVE, base=, targetID=/nscl, representation=, requestingEntity=null, protocol=null]
Nov 06, 2014 6:16:45 PM org.eclipse.om2m.comm.coap.CoapMessageDeliverer service
INFORMATION: check point: requestIndication sent and waiting for responseConfirm
Nov 06, 2014 6:16:45 PM org.eclipse.om2m.comm.coap.CoapMessageDeliverer getCoapStatusCode
INFORMATION: The received code is STATUS_AUTHORIZATION_NOT_ADDED
INFORMATION: check point : The code is 4.01
INFORMATION: the responseConfirm: ResponseConfirm [statusCode=STATUS_AUTHORIZATION_NOT_ADDED, representation=<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<om2m:errorInfo xmlns:om2m="link" xmlns:xmime="link">
    <om2m:statusCode>STATUS_AUTHORIZATION_NOT_ADDED</om2m:statusCode>
    <om2m:additionalInfo>Requesting Entity should not be null</om2m:additionalInfo>
</om2m:errorInfo>
, resourceURI=null]
INFORMATION: CoAP Response parameters set
Nov 06, 2014 6:16:45 PM org.eclipse.om2m.comm.coap.CoapMessageDeliverer deliverRequest
INFORMATION: the response= ACK-4.01   MID=26068, Token=[], OptionSet=[], "<?xmlversion="1.0" ".. 22 bytes
I know my question is more related to the CoAP client (CoAP header) but if you already have encountered the same problems please let me know.
regards,
Fesseha
Re: Using CoAP based applications (Copper vs Erbium) [message #1464410 is a reply to message #1464204] Fri, 07 November 2014 09:22 Go to previous messageGo to next message
Ok, let's try to investigate this issue.
Technically, I think that all URI parameters goes in the "Uri-Query" option of the CoAP protocol.
So, try to add the option: "Uri-Query" with the value: "authorization=admin:admin" to your CoAP request (instead of adding it as a URI parameter) and let's see.
Mahdi
Re: Using CoAP based applications (Copper vs Erbium) [message #1464423 is a reply to message #1464410] Fri, 07 November 2014 09:40 Go to previous messageGo to next message
Hey Mahdi,
Yes you are right, it should be set as a uri-query. It worked for me using this function
coap_set_header_uri_query(request, "?authorization=admin:admin");
thanks
Re: Using CoAP based applications (Copper vs Erbium) [message #1516129 is a reply to message #1464423] Thu, 18 December 2014 12:26 Go to previous messageGo to next message
hey guys,
Ive a small question.
By default in response messages the CoAP engine in OM2M sets the block size to 512bytes. For eg, just right after registering an Application resource, in the response the Application representation is included (as you know this representation is huge for small devices) and for this the first response is sent with szx = 512. Is it by any means possible to reduce this size???? Confused
regards
Re: Using CoAP based applications (Copper vs Erbium) [message #1516143 is a reply to message #1516129] Thu, 18 December 2014 12:39 Go to previous messageGo to next message
I think that returning the representation of the created resource is useless in constraint environment.
So I suggest you to go to "org.eclipse.om2m.comm.coap" plugin and update the "CoapServer.java".
Update the following code (line 242) :
if(responseConfirm.getRepresentation()!=null){
           //filling in the fields of the Coap response
    	   response.setPayload(responseConfirm.getRepresentation());
like this:
      if(statusCode != 2.01){
Tell me is this update meets your need.
If yes, I will push a patch to the git.
cheers
[Updated on: Thu, 18 December 2014 12:40] by Moderator
Re: Using CoAP based applications (Copper vs Erbium) [message #1517551 is a reply to message #1516143] Fri, 19 December 2014 10:31 Go to previous messageGo to next message
hallo,
I added that condition and the result was the same. The first message of the response to application registration is still 584bytes long (on the wire) with [Block2: NUM:0, M:8, SZX:512] header. I looked for this default response size even in 'Californium' but without success.
°^°^°^°^°Merry Christmas and Happy 2015°^°^°^°^°
regards,
Re: Using CoAP based applications (Copper vs Erbium) [message #1517558 is a reply to message #1517551] Fri, 19 December 2014 10:37 Go to previous messageGo to next message
Could you post the body that you get in the response ?
Mahdi
Re: Using CoAP based applications (Copper vs Erbium) [message #1517560 is a reply to message #1517558] Fri, 19 December 2014 10:40 Go to previous messageGo to next message
Just to be sure, after updating the coap plugin you should build all the project starting from the parent, in such a way that the new version of the coap plugin is added to your NSCL product.
Re: Using CoAP based applications (Copper vs Erbium) [message #1517677 is a reply to message #1517560] Fri, 19 December 2014 12:22 Go to previous messageGo to next message
Yea I've done that. I also tried to add the 'protocol' query in the OM2M code if it could help, but it does not have change. Previously the protocol is always shown as null, whether set or unset in requests. I actually talked about this to let you know that I can actually see the effect of the changes I make to the code.
Look at the attached pics.
  • Attachment: OM2M.png
    (Size: 146.41KB, Downloaded 696 times)
  • Attachment: CoAP POST.png
    (Size: 127.42KB, Downloaded 698 times)
Re: Using CoAP based applications (Copper vs Erbium) [message #1517683 is a reply to message #1517677] Fri, 19 December 2014 12:25 Go to previous messageGo to next message
The problem is clear here, you must use && instead of || in your if condition like this:
       if(statusCode != 2.01 && statusCode != 5.03 ){
Re: Using CoAP based applications (Copper vs Erbium) [message #1522742 is a reply to message #1517683] Mon, 22 December 2014 09:04 Go to previous messageGo to next message
No, the statusCode can not be both 2.01 and 5.03 at the same time. I used || because both situations had bigger payload in the response message.
Re: Using CoAP based applications (Copper vs Erbium) [message #1522930 is a reply to message #1522742] Mon, 22 December 2014 11:26 Go to previous messageGo to next message
Trust me, this is not what my code did.
My code says: if the statusCode is different from 2.01 and is also different from 5.03 then set the payload to the response.
In other words the payload will not be set for 2.01 and even 5.03, and this is what you want.
I suggest you to reread carefully my code Wink
[Updated on: Mon, 22 December 2014 11:30] by Moderator
Re: Using CoAP based applications (Copper vs Erbium) [message #1524448 is a reply to message #1522930] Tue, 23 December 2014 07:46 Go to previous messageGo to next message
Yea you are right! Thanks for the help. It is not setting the payload now. Is it still possible to know how to change the default block size from 512bytes instead of silencing all the response?
Re: Using CoAP based applications (Copper vs Erbium) [message #1585895 is a reply to message #1524448] Mon, 26 January 2015 09:51 Go to previous messageGo to next message
hello guys,
Have you noticed a problem on the CoAP message deliverer during block wise transfer?
The situation is like this, an Application sends a request to the NSCL to get a resource of an already registered application (DA). By default the NSCL sends (forwards) a request without setting any CoAP block headers. But the response from the DA holds BLOCK2 header. The message id should be continuous in this case and the NSCL should continue with an incremented mid and the new BLOCK2 header. But the message id jumps to some new random value which makes it difficult for the other side (DA). Take a look at the attached Wireshark screen shot.
Any suggestions?
Re: Using CoAP based applications (Copper vs Erbium) [message #1597821 is a reply to message #1585895] Mon, 02 February 2015 10:32 Go to previous messageGo to next message
Hello Fesseha,
What i see from the wireshark log is that there is a GET request which is divided in 2 blocks (block 0 and block 1). The error message is a SERVICE UNAVAILABLE (5.03). This means that all the blocks have been assembled but there is no service to respond to the GET request. I don't think there is an issue with the blockwise operation here. However to make sure of this, you should investigate a little deeper and be sure that the request is assembled correctly. i strongly believe it is not the CoAP client problem and you should see in the service part and check if it is available and why it is not responding.
Mahdi & Elvis
Re: Using CoAP based applications (Copper vs Erbium) [message #1740691 is a reply to message #1464410] Wed, 17 August 2016 06:34 Go to previous messageGo to next message
Hi Mahdi,
I wonder that in OM2M version 1.0.0, how the authorization will be done. I tried to put the Query parameter: authorization=admin:admin to the request uri: coap://127.0.0.1:5683/~/in-cse/in-name?authorization=admin:admin, but the server responsed with an error 4.03 Unknown or unauthorized originator. Do you have any idea?
Thank you in advanced
Son
Mahdi Ben Alaya wrote on Fri, 07 November 2014 14:22
Mahdi
[Updated on: Wed, 17 August 2016 06:34] by Moderator
Re: Using CoAP based applications (Copper vs Erbium) [message #1741005 is a reply to message #1740691] Mon, 22 August 2016 06:52 Go to previous messageGo to next message
Hi Son Duong.
The OneM2M version of the OM2M platform uses the Californium library to implement the general protocol binding. For a better
understanding of the binding, you can take a look at the protocols specifications.
I've looked at the two popular CoAP clients: the Copper plugin and the libcoap CLI tool. Both of them are, at this time,
not suitable to be used with this binding, since they do not support multiple custom options (you can read about them in the mentioned specifications).
I built a simple CoAP client, using the Californium library, with the purpose of demonstrating its usage with the general
CoAP binding. The provided examples are analogous to the ones of the HTTP tutorial.
I'd also like to mention the changed usage of the name attribute. In previous releases of the platform,
there was a special field (X-M2M-NM in HTTP), which was used for specifying the name of the resource, which was to be created.
In the latest version, this field is replaced, by a suitable attribute ("rn" or "nm"). This change is also included in the provided client.
I changed the default platform CoAP port to 5683, in the config.ini file of the suitable CSE unit, since the plugin doesn't use
the TLS encryption yet. The attached "coapmonitor.jar" application uses the 5685 port instead (just as an example).
[Updated on: Mon, 22 August 2016 06:53] by Moderator
Re: Using CoAP based applications (Copper vs Erbium) [message #1741030 is a reply to message #1741005] Mon, 22 August 2016 09:01 Go to previous messageGo to next message
Hi Klemen,
this is exactly what I am looking for, thank you very much! Smile
Klemen Petrovcic wrote on Mon, 22 August 2016 10:52
Hi Son Duong.
Re: Using CoAP based applications (Copper vs Erbium) [message #1741143 is a reply to message #1741030] Tue, 23 August 2016 06:41 Go to previous messageGo to next message
Hallo Klemen,
I tried your Coap client and it works fine, thank you once again. May I ask you another question? In the OM2M package, there is already a LAMP example (plugin number 30) and I would like to switch on the lamp using Coap request. Based on your Coap client example, I created another request function, called: returnCreatePostRequestString() which is used to create the POST request to switch on the LAMP, and I post this request to the address: coap://127.0.0.1:5683/~/mn-cse/mn-name/LAMP_0?op=setOn&lampid=LAMP_0.
Here is my returnCreatePostRequestString() function to create the POST request:
public static Request returnCreatePostRequestString() {
		// TODO Auto-generated method stub
		// Used to POST something
		Request createSrc = new Request(Code.POST);
		byte[] b10 = new byte[8];
		new Random().nextBytes(b10);
		createSrc.setToken(b10);
		createSrc.getOptions()
		   .setContentFormat(MediaTypeRegistry.APPLICATION_XML)
		   .setAccept(MediaTypeRegistry.APPLICATION_XML)
		   .addOption(new Option(256, "admin:admin"));
		return createSrc;
In the request I just added the option authorization admin:admin, and it works fine with HTTP (tested using Simple REST Client) but unfortunatelly not for the CoAP, the Coap response show Error Code 4.00. It stacked with this Error Log:
[2016-08-23 12:40:44,580 INFO] - org.eclipse.om2m.core.router.Router
Received request in Router: RequestPrimitive [operation=5,
 to=/mn-cse/mn-name/LAMP_0,
 from=admin:admin,
 returnContentType=application/xml,
 requestContentType=application/xml,
 queryStrings={}]
[2016-08-23 12:40:44,581 INFO] - org.eclipse.om2m.core.router.Router
Request handling in the current CSE: /mn-cse/mn-name/LAMP_0
[2016-08-23 12:40:44,582 INFO] - org.eclipse.om2m.core.redirector.Redirector
Sending notification to IPE: sample
May you help me where did I do wrong?
Thank you very much
Son
Re: Using CoAP based applications (Copper vs Erbium) [message #1741276 is a reply to message #1741005] Wed, 24 August 2016 06:17 Go to previous messageGo to next message
Hi Klemen,
Could you direct me how to use the CoAP files you gave? I am kinda stuck here.
Thanks for help.
[Updated on: Wed, 24 August 2016 06:20] by Moderator
Re: Using CoAP based applications (Copper vs Erbium) [message #1741283 is a reply to message #1741276] Wed, 24 August 2016 06:39 Go to previous messageGo to next message
Hi Muhammad,
for sending the CoAP request, you should run the CoAP_Client package. For receiving the CoAP response, in this case is the notification, you should run the CoAP_Monitor package. Just download the files and import them to Eclipse or Netbean and run.
Son
Re: Using CoAP based applications (Copper vs Erbium) [message #1741634 is a reply to message #1741005] Fri, 26 August 2016 09:25 Go to previous messageGo to next message
hi Klemen,
I have another question about the CoAP Monitor server.
I tried to run the CoAP monitor jar file under port 5685. And I created a subscription container in my AE which set the notification uri (nu) as coap://127.0.0.1:5685/monitor. However when I run the plugin, it was not able to create the subscription container and it show the 5001 error:
[2016-08-26 15:17:03,149 INFO] - org.eclipse.om2m.core.router.Router
ResourceController to be used [SubscriptionController]
[2016-08-26 15:17:03,164 INFO] - org.eclipse.om2m.core.notifier.Notifier
Sending notify request to: coap://127.0.0.1:5685/monitor
[2016-08-26 15:17:03,164 INFO] - org.eclipse.om2m.core.comm.RestClient
the requestIndication RC: RequestPrimitive [operation=5,
 to=coap://127.0.0.1:5685/monitor,
 from=/mn-cse,
 content=<?xml version="1.0" encoding="UTF-8"?>
<m2m:sgn xmlns:m2m="http://www.onem2m.org/xml/protocols">
   <vrq>true</vrq>
   <sud>false</sud>
</m2m:sgn>
[2016-08-26 15:17:03,164 INFO] - org.eclipse.om2m.core.router.Router
OM2M exception caught in Router: No RestClient service found for protocol: coap
Response in Router= ResponsePrimitive [responseStatusCode=5001,
 content=No RestClient service found for protocol: coap,
 to=admin:admin,
 from=/mn-cse,
 contentType=text/plain,
I think the problem because it can not find the coap binding in the RestClient class.
Do you have any idea how to fix this problem. Did the coap monitor server work in your system?
Thank you
Son
Re: Using CoAP based applications (Copper vs Erbium) [message #1742555 is a reply to message #1741634] Mon, 05 September 2016 02:11 Go to previous messageGo to next message
Hi Son Duong,
Thank you alot for helping me out earlier. I downloaded the files and imported it to Eclipse neon (this is a separate eclipse ide which does not deal with OM2M project at all). Attached with reply is an image please have a look and guide.
Thank you for your help.
  • Attachment: Untitled.png
    (Size: 140.28KB, Downloaded 555 times)
Re: Using CoAP based applications (Copper vs Erbium) [message #1742562 is a reply to message #1742555] Mon, 05 September 2016 04:23 Go to previous messageGo to next message
Hi Muhammad,
I think you miss the californium libraries. You can download them here: https://mvnrepository.com/artifact/org.eclipse.californium/californium-core and here https://mvnrepository.com/artifact/org.eclipse.californium/element-connector . After downloading, just add them to your project and everything will work fine again.
Son
Re: Using CoAP based applications (Copper vs Erbium) [message #1743381 is a reply to message #1742562] Wed, 14 September 2016 14:19 Go to previous messageGo to next message
Hi all,
I'm trying to apply CoAP into the subscribe/notify scenario with sensor create value and send to the actuator. I did with Http and it works normally; however, when I apply the coap monitor in the actuator, the actuator receives the value from sensor but the Response Status code in sensor console is 5000. I use the CoAPMonitor which provided above. Anyone has solution for this? Thanks in advanced!!
Re: Using CoAP based applications (Copper vs Erbium) [message #1743578 is a reply to message #1743381] Fri, 16 September 2016 10:05 Go to previous messageGo to next message
Hi Trung Luu,
the 5000 response is probably due to an incorrect return coap code. In the HTTP monitor.jar, the application returns a response code 204 (no content). I didn't find a suitable corresponding code for the coap protocol, so I returned a hardcoded string, which is incorrect.
Re: Using CoAP based applications (Copper vs Erbium) [message #1743745 is a reply to message #1743578] Mon, 19 September 2016 08:03 Go to previous messageGo to next message
Hi Klemen,
I have one more question. When I tried to capture the traffic using wireshark, I searched for coap but it showed udp instead, do you know why this happed`?
Thank you!
Re: Using CoAP based applications (Copper vs Erbium) [message #1743764 is a reply to message #1743745] Mon, 19 September 2016 09:50 Go to previous messageGo to next message
Son Duong wrote on Mon, 19 September 2016 12:03
Hi Klemen,
Thank you!
This is correct. HTTP uses TCP, while CoAP is implemented on the UDP protocol stack.
Re: Using CoAP based applications (Copper vs Erbium) [message #1786289 is a reply to message #1741005] Sun, 29 April 2018 20:46 Go to previous messageGo to next message
Hi Klemen Petrovcic.
First of all, thank you for uploading the sample application.
I tried to send CoAP message using your application. but null pointer exception appeared like a picture i uploaded when any message arrived to IN-CSE. so your application tried to send again but after time to live, it closed without explicit answer message.
how do i miss it?
  • Attachment: nullerror.png
    (Size: 79.36KB, Downloaded 262 times)
Re: Using CoAP based applications (Copper vs Erbium) [message #1786747 is a reply to message #1786289] Thu, 10 May 2018 10:33 Go to previous messageGo to next message
Hi Soyong Kim, do you already know how to solve it?
Re: Using CoAP based applications (Copper vs Erbium) [message #1787502 is a reply to message #1786747] Sun, 27 May 2018 08:38 Go to previous message
Hi Paulo
i solved the problem by modifying CoAPServer class in OM2M source code
i think the problem was "to=coap://localhost/~/in-cse" in the picture i uploaded.
so i modified requestPrimitive.setTo(request.getURI())
to request.Primivice.setTo(request.getOptions().getURIString()) in CoAPServer class
I think this way is not good,
but i don't know how do i solve the problem without modifying the code..
if anyone knows any other way, let me know.
  • Attachment: null.png
    (Size: 83.73KB, Downloaded 237 times)
Previous Topic:CoAP between App and in-cse
Next Topic:A nullpointerException occur when i send CoAP message to IN-CSE
Current Time: Sat Jul 19 12:25:59 EDT 2025
Powered by FUDForum. Page generated in 0.13349 seconds
