Weblogic startup script ? [message #151607] |
Tue, 13 December 2005 08:15  |
I've got a big problem using Weblogic Server 8.1 with WTP0.7.1 or
WTP1.0RC3: The Servers window is never notified when the Weblogic server
is up.
->I've pointed to the correct domain / scripts defining my Weblogic server
->The start script does correctly start Weblogic server (I've got <Server
started in RUNNING mode> & <Thread "ListenThread.Default" listening on port
9001, ip address xx.xx.xx.xx> messages in the console)
->In WTP1.0RC3 I've got a "Timeout waiting for Generic BEA Weblogic v8.1 to
start. Server did not start after 75000s" error message.
The script I'm using never returns/exits while Weblogic is up.
Question:
->Is there a way to have the Generic Weblogic v8.1 server definition correctly
recognising that the server is up & running, even when the start script never
returns ?
->Or do you know a way to do a start script for Weblogic that would return as
soon as the server is up ?
Thanks a lot, I'm pretty blocked by this.
Romain
Re: Weblogic startup script ? [message #152578 is a reply to message #151645] |
Thu, 15 December 2005 15:48  |
The generic server framework determines when the server is running by
repeatedly attempting to establish an http connection with the server on the
specified port. Note: the process which is executed by your designated start
script must not terminate prior to stopping your server (the standard
startWeblogic scripts work here); if it does, the server is set to the
stopped state; this may be what is occurring for you; if this is not the
case, please file a bugzilla bug.
-Rob
"Romain FARAUT" <romain.faraut@lodh.com> wrote in message
news:220f50612bb57d94711534f3fc372860$1@www.eclipse.org...
> Well,
> in fact I was deploying to the Admin server, so now I created an
> additional server, devServer... An I have now a script that starts the
> server...
> When launched manually it works perfectly, when started via the "Servers"
> eclipse panel the server get launched, tells me "Server 'devServer' was
> started ... Please refer to server log files for completion status ..."
> Everything is okay, but I now got in the Servers view :
> First:
> "Status Starting..." / "Synchronized"
> 10 seconds later:
> "Stopped" / "republish"
> + A popup :
> "Starting server - Generic BEA Weblogic Server v8.1" /
> "Server Generic BEA Weblogic Server v8.1 failed to start."
> While the server gets really started + everything is fine (server is
> running)
> My question:
> What does eclipse WTP use to "know" that a server startup is okay or is
> running ?
> Cheers, r0main
FUDForum. Page generated in 0.03116 seconds
