Home » Language IDEs » Java Development Tools (JDT) » bootclasspath not working in m8?
bootclasspath not working in m8? [message #151392] Mon, 29 March 2004 13:32 Go to next message
I just switched from M7 to M8 and now it appears like the bootclasspath is
not being set correctly during debug and run. I have jars that need to be
loaded before the JRE system library. Is there some new configuration to
do this?
Re: bootclasspath not working in m8? [message #151413 is a reply to message #151392] Mon, 29 March 2004 14:45 Go to previous messageGo to next message
> do this?
Clarification: For Junit Run/Debug, it appears the Bootstrap Entries are
being ignored. It is working for Java Application.
Re: bootclasspath not working in m8? [message #151488 is a reply to message #151413] Tue, 30 March 2004 00:51 Go to previous messageGo to next message
>>do this?
I've run into this issue as well. A quick workaround is to use the
"-Xbootclasspath/p:" switch in the VM arguments box.
I've entered a bug report (Bug 56693).
Sean
Re: bootclasspath not working in m8? [message #151959 is a reply to message #151488] Wed, 31 March 2004 22:56 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
Sean Kirby wrote:
> James E wrote:
>>> bootclasspath is
>>> to be
>>> do this?
> Sean
hey Sean,
I am not sure whether i have the same problem (which i have reported in
bug 55287), but I would like to find out whether i could use your
workaround. can you please elaborate on how i can use the
"-Xbootclasspath" switch?
thanks,
Vijay
Re: bootclasspath not working in m8? [message #151964 is a reply to message #151959] Wed, 31 March 2004 23:02 Go to previous message
Using -X options depends on your vm. For a summary of supported -X
options execute "java -X"
On Sun 1.4.2_01 it says this about -Xbootclasspath
-Xbootclasspath:<directories and zip/jar files separated by ;>
set search path for bootstrap classes and resources
-Xbootclasspath/a:<directories and zip/jar files separated by ;>
append to end of bootstrap class path
-Xbootclasspath/p:<directories and zip/jar files separated by ;>
prepend in front of bootstrap class path
Vijay Aravamudhan wrote:
> Sean Kirby wrote:
>> James E wrote:
>>>> bootclasspath is
>>>> to be
>>>> configuration to
>>>> do this?
>> Sean
> hey Sean,
> thanks,
> Vijay
Previous Topic:Refactoring
Next Topic:Eclipse building equivalence in Ant
Current Time: Sun Jul 20 18:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.04457 seconds
