Home » Modeling » EMF » How to change ConstraintStatus severity
How to change ConstraintStatus severity [message #1512265] Mon, 15 December 2014 10:55 Go to next message
Hi all,
I'd like to use Java classes to do most of my model validation. Because the model I'm working with is HUGE, I would like to define just a single class to validate, and report all possible validation severities (INFO, WARNING, ERROR, etc.) for a given model type.
Currently, the only way I can figure out how to set the severity is in the <constraint> extension point element (e.g. severity="ERROR", etc.) If my model has a hundred or so types, does that mean I need to write a constraint class for each severity level/type combination? In other words, if I have a type "A" do I need a validateAInfos, validateAErrors, validateAWarnings, etc. etc.? This seems like it would lead to an awful lot of duplicated code.
Thanks in advance,
Bob
Re: How to change ConstraintStatus severity [message #1512431 is a reply to message #1512265] Mon, 15 December 2014 13:51 Go to previous messageGo to next message
Hi, Bob,
A couple of the ConstraintStatus factory method signatures include a
severity parameter. I'm fairly certain that I have at one time or
another used this to return different messages and severities from a
single constraint, depending on various factors.
So, rather than asking the IValidationContext to create the result
status for you, you can just invoke one of these factory methods to
customize the result.
HTH,
Christian
On 2014-12-15 15:55:57 +0000, Robert Brodt said:
> Hi all,
> Thanks in advance,
> Bob
Re: How to change ConstraintStatus severity [message #1512587 is a reply to message #1512431] Mon, 15 December 2014 16:56 Go to previous messageGo to next message
Thanks for the quick reply Christian. I've thought of that too. The problem is that the validate(IValidationContext) method of my AbstractModelConstraint implementation is passed an IValidationContext, but unfortunately all of the ConstraintStatus constructors require the IModelConstraint contained in the validation context, which is not available (publicly). Thus, you are forced to use IValidationContext#createFailureStatus() or IValidationContext#createSuccessStatus() to construct the IStatus object returned by validate(). This seems really restrictive to me Sad
I don't really see any way around this - am I missing something?
EDIT: Oops, yes I am missing something Wink I just noticed the static createStatus() methods which, indeed, accept a context and severity. Never mind Smile
[Updated on: Mon, 15 December 2014 17:04] by Moderator
Re: How to change ConstraintStatus severity [message #1512608 is a reply to message #1512587] Mon, 15 December 2014 17:22 Go to previous messageGo to next message
Hi, Bob,
Don't use the ConstraintStatus constructors, but the static factory
methods. To these you pass the validation context, not the current
IModelConstraint. Although, you could just get the IModelConstraint
like this:
ConstraintRegistry.getInstance().getDescriptor(
ctx.getCurrentConstraintId())
which is what the static factory methods do. That's all public API.
HTH,
Christian
> object returned by validate(). This seems really restrictive to me :(
Re: How to change ConstraintStatus severity [message #1512749 is a reply to message #1512608] Mon, 15 December 2014 20:11 Go to previous message
Yes, that does help - thanks Christian! Smile
Previous Topic:Copyright notice not generated
Next Topic:Making URIHandlerImpl more REST-able
Current Time: Sat Jul 19 11:58:09 EDT 2025
Powered by FUDForum. Page generated in 0.05602 seconds
