Home » Language IDEs » C / C++ IDE (CDT) » debugger showing structure arrays greater 100
debugger showing structure arrays greater 100 [message #150450] Mon, 01 August 2005 06:16 Go to next message
Originally posted by: frank.morauf.salzbrenner.com
When using arrays of structures greater then 100, then in debugger view
variables these are grouped in 100. All groups are showing the same, this
is the first group from 0 to 99.
This happens not if using not a structur but a simple type.
struct MyStuct
Re: debugger showing structure arrays greater 100 [message #150513 is a reply to message #150450] Tue, 02 August 2005 14:45 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Seems to work for me. Can you provide a test case?
"Frank Morauf" <frank.morauf@salzbrenner.com> wrote in message
news:ee8a0340db91b559d979bfd411ab1eb4$1@www.eclipse.org...
> struct MyStuct
Re: debugger showing structure arrays greater 100 [message #150969 is a reply to message #150513] Tue, 09 August 2005 05:07 Go to previous messageGo to next message
Please try this piece of code:
#include "memory.h"
struct test_struct
int a;
char b;
int main(void)
struct test_struct s[200];
memset(s, 0, sizeof(s));
s[1].a = 1;
s[99].a = 99;
s[100].a = 100;
s[101].a = 101;
s[199].a = 199;
return 0; /* stop debugger here */
Now look in debug view variables at s[101]: it shows the contents of s[1],
similar is s[199]. It seems that the block form 100 to 199 is a copy of
the block from 0 to 99. If making the array greater (e.g. s[500]), then
every block above 100 is a copy of the first block.
This happens NOT if using only ONE standard c-type (like int) in the
struct or if using an array of standard c-types.
Re: debugger showing structure arrays greater 100 [message #150978 is a reply to message #150969] Tue, 09 August 2005 14:11 Go to previous messageGo to next message
What is your environment? This example works fine on Windows.
news:3032302a216200833ab24b922a0d0980$1@www.eclipse.org...
> #include "memory.h"
> struct test_struct
> int a;
> char b;
> int main(void)
> s[1].a = 1;
> s[99].a = 99;
> s[100].a = 100;
> s[101].a = 101;
> s[199].a = 199;
Re: debugger showing structure arrays greater 100 [message #150992 is a reply to message #150978] Wed, 10 August 2005 06:20 Go to previous messageGo to next message
I'm using the latest Eclipse 3.1.0 und the latest CDT 3.0.0 on Windows XP
but this problem is present since Eclipse 3.0.0 and CDT 2.1.
I've tried it with native cygwin gdb and a cross gdb.
I try to explain:
Let the simple program run to "return 0;"
Window->Open Perspective->Debug
Window->Show View->Variables
In this window:
enable in the local menu "Vertical View Orientation".
In this window you can see the local variable s, which is grouped from 0
to 99 and 100 to 199.
Now unfold the group 100 to 199 and make a single left click on s[101].
Now look at the contents in the detail pane view: this is wrong!
Re: debugger showing structure arrays greater 100 [message #150998 is a reply to message #150992] Wed, 10 August 2005 08:17 Go to previous messageGo to next message
Originally posted by: stefanm.uniblue.net
Hi Frank,
I have tried the example aswell. Difference is that I am using MinGW.
Example works fine for me.
Stefan
> I try to explain:
> In this window:
Re: debugger showing structure arrays greater 100 [message #151007 is a reply to message #150992] Wed, 10 August 2005 10:52 Go to previous message
Now I got it. I was looking at the variable value not the value in the
Detail pane.
Created Bugzilla entry -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=106632.
Thanks you.
news:cb7ec78570e7e47d9d5e5db16b75837b$1@www.eclipse.org...
> I try to explain:
> In this window:
Previous Topic:Profiling C/C++ application
Next Topic:crash while linking my project
Current Time: Sat Jul 19 18:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
