Cannot run Eclipse anymore [message #150946] |
Thu, 04 May 2006 08:20  |
Originally posted by: elaertis.gmail.com
I have been using Eclipse for the last month without severe problems.
Today, I get this weird pop-up message when trying to start it:
An error has occurred. See the log file
/.../.../workspace/.metadata/.log.
Inside the .log file:
!SESSION 2006-04-06 09:24:33.253
eclipse.buildId=M20050929-0840
java.version=1.4.2_08
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2006-05-04 13:15:05.598
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IProject
at
org.eclipse.ui.internal.ide.model.WorkbenchAdapterFactory.<init >(WorkbenchAdapterFactory.java:35)
at
org.eclipse.ui.internal.ide.model.WorkbenchAdapterBuilder.re gisterAdapters(WorkbenchAdapterBuilder.java:33)
at
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.initialize(I DEWorkbenchAdvisor.java:132)
at
org.eclipse.ui.application.WorkbenchAdvisor.internalBasicIni tialize(WorkbenchAdvisor.java:172)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1002)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Cannot run Eclipse anymore [message #150967 is a reply to message #150951] |
Thu, 04 May 2006 10:50   |
Thank you for your answer, I have just posted a truncated version of the
log file including only the last error messages.
This is the whole file....
!ENTRY org.eclipse.jdt.ui 4 10001 2006-04-06 09:30:23.512
!MESSAGE Internal Error
!STACK 1
Java Model Exception: Java Model Status [Cannot nest
'Simulator/hybridmodel' inside output folder 'Simulator']
at
org.eclipse.jdt.internal.corext.buildpath.ClasspathModifier. updateClasspath(ClasspathModifier.java:1601)
at
org.eclipse.jdt.internal.corext.buildpath.ClasspathModifier. removeFromClasspath(ClasspathModifier.java:447)
at
org.eclipse.jdt.internal.corext.buildpath.RemoveFromClasspat hOperation.run(RemoveFromClasspathOperation.java:69)
at
org.eclipse.jdt.internal.ui.util.BusyIndicatorRunnableContex t$BusyRunnable.internalRun(BusyIndicatorRunnableContext.java :113)
at
org.eclipse.jdt.internal.ui.util.BusyIndicatorRunnableContex t$BusyRunnable.run(BusyIndicatorRunnableContext.java:80)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.jdt.internal.ui.util.BusyIndicatorRunnableContex t.run(BusyIndicatorRunnableContext.java:126)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.newsourcepage .HintTextGroup$2.linkActivated(HintTextGroup.java:213)
at org.eclipse.ui.forms.widgets.FormText.activateLink(FormText. java:1466)
at
org.eclipse.ui.forms.widgets.FormText.handleMouseClick(FormT ext.java:1281)
at org.eclipse.ui.forms.widgets.FormText.access$19(FormText.jav a:1255)
at org.eclipse.ui.forms.widgets.FormText$6.mouseUp(FormText.jav a:387)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.jdt.core 4 964 2006-04-06 09:30:23.514
!MESSAGE Cannot nest 'Simulator/hybridmodel' inside output folder
'Simulator'
!SESSION 2006-04-11 19:07:50.604
!ENTRY org.eclipse.core.resources 2 10035 2006-04-11 19:07:55.301
!MESSAGE A workspace crash was detected. The previous session did not exit
normally.
!SESSION 2006-04-14 22:19:28.161
!ENTRY org.eclipse.core.resources 2 10035 2006-04-14 22:19:34.600
normally.
!SESSION 2006-05-04 12:38:59.155
!ENTRY org.eclipse.osgi 2006-05-04 12:39:03.145
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.core.resources (59).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle
org.eclipse.core.resources.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.core.internal.resources.ResourceException: Problems
reading workspace tree.
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:166)
at
org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:891)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:623)
at
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1301)
at
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1872)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1642)
at
org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:357)
at
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:31)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
... 31 more
Root exception:
org.eclipse.core.internal.resources.ResourceException(null)[ 567]:
java.io.EOFException
at java.io.DataInputStream.readFully(DataInputStream.java:268)
at java.io.DataInputStream.readLong(DataInputStream.java:470)
at
org.eclipse.core.internal.resources.ResourceInfo.readFrom(Re sourceInfo.java:282)
at
org.eclipse.core.internal.resources.SaveManager.readElement( SaveManager.java:468)
at
org.eclipse.core.internal.watson.ElementTreeReader$1.readDat a(ElementTreeReader.java:64)
at
org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:82)
at
org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:96)
at
at
at
at
org.eclipse.core.internal.dtree.DataTreeReader.readTree(Data TreeReader.java:137)
at
org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dTree(ElementTreeReaderImpl_1.java:102)
at
org.eclipse.core.internal.watson.ElementTreeReader.readTree( ElementTreeReader.java:128)
at
org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dDeltaChain(ElementTreeReaderImpl_1.java:84)
at
org.eclipse.core.internal.watson.ElementTreeReader.readDelta Chain(ElementTreeReader.java:101)
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTrees(WorkspaceTreeReader_1.java:221)
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-05-04 12:39:03.168
!STACK 1
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-05-04 12:39:10.816
!ENTRY org.eclipse.osgi 2006-05-04 12:39:13.224
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 31 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-05-04 12:39:13.245
!STACK 1
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-05-04 12:42:59.306
!ENTRY org.eclipse.osgi 2006-05-04 12:43:02.905
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 31 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-05-04 12:43:02.923
!STACK 1
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-05-04 12:44:44.272
!ENTRY org.eclipse.osgi 2006-05-04 12:44:47.191
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 31 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-05-04 12:44:47.210
!STACK 1
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-05-04 13:15:03.257
!ENTRY org.eclipse.osgi 2006-05-04 13:15:05.577
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 31 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
FUDForum. Page generated in 0.08441 seconds
