Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ECP reuse a ViewModel
ECP reuse a ViewModel [message #1498791] Thu, 04 December 2014 12:22 Go to next message
is there a way to reuse a view model? I created a "base" view model and want to add this in other viewmodels.
Dennis
Re: ECP reuse a ViewModel [message #1499581 is a reply to message #1498791] Fri, 05 December 2014 03:37 Go to previous messageGo to next message
If the domain model elements inherit from each other, you can use View
proxies for this...
Am 04.12.2014 18:22, schrieb Dennis Melzer:
> Hello,
> Regards,
> Dennis
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: ECP reuse a ViewModel [message #1499625 is a reply to message #1499581] Fri, 05 December 2014 04:21 Go to previous messageGo to next message
If i click View Proxy in the IDE-Tooling , it will create a new VerticalLayout which contains some controls. But how can I select another view?
Re: ECP reuse a ViewModel [message #1502271 is a reply to message #1499625] Sun, 07 December 2014 08:57 Go to previous messageGo to next message
what do you mean exactly by "It will create a new VerticalLayout"?
During runtime? Do you reference another view by its ID?
Best regards
Jonas
Am 05.12.2014 10:21, schrieb Dennis Melzer:
> another view?
Re: ECP reuse a ViewModel [message #1503406 is a reply to message #1502271] Mon, 08 December 2014 07:37 Go to previous messageGo to next message
I add to a viewmodel (screenshot1) a view proxy model (screenshot2) the result are two vertical layouts (screenshot 3).
EDIT:
That occurs when i click the refresh button in the preview editor
[Updated on: Mon, 08 December 2014 07:41] by Moderator
Re: ECP reuse a ViewModel [message #1504886 is a reply to message #1503406] Tue, 09 December 2014 11:59 Go to previous messageGo to next message
could it be, that this occurs only, if the preview is open? If so, this
seems to be a bug. View proxies are replaced during runtim and the
preview might do that. It should therefore work on a copy. Could you
retest this and report a BR?
Thanks!
Jonas
Am 08.12.2014 13:37, schrieb Dennis Melzer:
Re: ECP reuse a ViewModel [message #1504918 is a reply to message #1504886] Tue, 09 December 2014 12:30 Go to previous messageGo to next message
Yes first it's a view proxy model. If i press the refresh button it will replaced by the vertical layout.
What is the view proxy id? A Resource URI? The path to the other view model?
Re: ECP reuse a ViewModel [message #1505721 is a reply to message #1504918] Wed, 10 December 2014 03:56 Go to previous messageGo to next message
That is the id which is used to register the view model (in the
extension point).
Am 09.12.2014 18:30, schrieb Dennis Melzer:
> model?
Re: ECP reuse a ViewModel [message #1505726 is a reply to message #1505721] Wed, 10 December 2014 04:01 Go to previous message
Ah okay perfect.
Thanks Smile
Previous Topic:Radio Buttons ECP
Next Topic:[EMF Facet] How to add new elements into the ModelExplorer
Current Time: Sun Jul 20 04:27:36 EDT 2025
Powered by FUDForum. Page generated in 0.05998 seconds
