Home » Newcomers » Newcomers » Eclipse 4.3 freezes on first startup on Linux Mint 16 without error messages(Eclipse displays the splash screen for a few seconds and then the splash screen turns blank.)
Eclipse 4.3 freezes on first startup on Linux Mint 16 without error messages [message #1339315] Wed, 07 May 2014 12:17 Go to next message
I've been trying to get Eclipse 4.3 Kepler running on my 64-bit Linux Mint 16. I have OpenJDK 7.
java -version
java version "1.7.0_55"
OpenJDK Runtime Environment (IcedTea 2.4.7) (7u55-2.4.7-1ubuntu1~0.13.10.1)
OpenJDK 64-Bit Server VM (build 24.51-b03, mixed mode)
Eclipse file
eclipse-standard-kepler-SR2-linux-gtk-x86_64.tar.gz
On startup Eclipse displays the splash screen which after a few seconds goes blank and nothing happens. Eclipse creates .eclipse directory but no workspace.
Contents of .eclipse directory:
org.eclipse.platform_3.8_155965261 org.eclipse.platform_4.3.2_1473617060_linux_gtk_x86_64
I have specified in the eclipse.ini file that it uses openJDK 7.
-vm
/usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java
When I use
eclipse -clean -consoleLog -debug
last two lines are
Time to load bundles: 5
Starting application: 5051
After which the splash screen goes blank and stays on indefinitely. When I force quit it with Ctrl-C I get an error message which differs from time to time for example
Eclipse: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
or
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
java: ../../src/xcb_io.c:274: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
or sometimes I get no error message at all.
I have tried googling for solutions and using Oracle's JDK 8 instead of OpenJDK but haven't managed to get it working.
[Updated on: Wed, 07 May 2014 14:53] by Moderator
Re: Eclipse 4.3 freezes on first startup on Linux Mint 16 without error messages [message #1342877 is a reply to message #1339315] Fri, 09 May 2014 00:04 Go to previous messageGo to next message
Hope it seems to be a kind of same issue what i am facing.
Check the link below
http://www.eclipse.org/forums/index.php/t/732891/
But in my case when i do eclipse -clean -consolelog - debug Eclipse opens up in debug mode i think.
Re: Eclipse 4.3 freezes on first startup on Linux Mint 16 without error messages [message #1504757 is a reply to message #1339315] Tue, 09 December 2014 09:30 Go to previous message
What this issue status? How to resolve it?
Kind Regards
Previous Topic:using GoogleDrive for Eclipse workspace
Next Topic:Mosquitto s/w for the solaris version
Current Time: Sun Jul 20 11:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.08528 seconds
