Home » Eclipse Projects » Remote Application Platform (RAP) » Getting the username after form-based authentication
Getting the username after form-based authentication [message #1498607] Thu, 04 December 2014 09:31 Go to next message
i'm using form-based authentication (with a servlet). Now i need the login name of the authenticated user. I found
RWT.getRequest().getUserPrincipal().getName();
but getRequest(...) is marked with 'This method is not recommended.'
Is it save to get the username with this method? If not, which is the correct way?
Re: Getting the username after form-based authentication [message #1499536 is a reply to message #1498607] Fri, 05 December 2014 02:53 Go to previous messageGo to next message
what about RWT.getRequest().getRemoteUser()?
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Getting the username after form-based authentication [message #1499605 is a reply to message #1499536] Fri, 05 December 2014 04:00 Go to previous messageGo to next message
getUserPrincipal().getName() and getRemoteUser() return the same values (at least in my case).
But i'm worrying about RWT.getRequest(). Here is the JavaDoc:
Returns the HttpServletRequest that is currently processed.
Note: This method is not recommended. Typical application code should not need to call this method. Processing requests from the client is up to the framework. In rare cases, an application may be wish to access request details such as certain HTTP headers.
I don't want to process requests, i just need the username. So, can i use this method?
Re: Getting the username after form-based authentication [message #1499627 is a reply to message #1499605] Fri, 05 December 2014 04:24 Go to previous message
Sure
Ivan Furnadjiev
Previous Topic:Modal and Modeless Shells
Next Topic:How to self-update RAP application?
Current Time: Sat Jul 19 14:26:14 EDT 2025
Powered by FUDForum. Page generated in 0.04587 seconds
