Home » Modeling » GMF (Graphical Modeling Framework) » Palette: how can I disable Note
Palette: how can I disable Note [message #149633] Mon, 10 September 2007 03:30 Go to next message
Originally posted by: juergen.sterr.brain-child.de
I have a problem. I want disable the funktion Note in the Palette.
How can I do that?
Jürgen
Re: Palette: how can I disable Note [message #149640 is a reply to message #149633] Mon, 10 September 2007 04:15 Go to previous messageGo to next message
I know this is not the most appropriate solution ...but it WORKS...
Open your ****DiagramEditor class and override the function
createpalleteroot() in the following way -
protected PaletteRoot createPaletteRoot(PaletteRoot existingPaletteRoot) {
PaletteRoot root = super.createPaletteRoot(existingPaletteRoot);
root.getDefaultEntry().getParent().getChildren().remove(3);
return root;
element #3 corresponds to the notes in the default toolentries provided
byu GMF.
Any alternate sloution is most welcome :-)
cheers,
-Arpit
Re: Palette: how can I disable Note [message #149648 is a reply to message #149640] Mon, 10 September 2007 05:13 Go to previous messageGo to next message
Thanks Arpit.
It works.
But how can I disable the option Note in the contextmenue?
It is still possible to create a Node.
Jürgen
Re: Palette: how can I disable Note [message #149851 is a reply to message #149633] Mon, 10 September 2007 12:57 Go to previous messageGo to next message
Originally posted by: slorenc.infogix.com
There is another way to do this which is described here.
http://wiki.eclipse.org/index.php/GMF_Tutorial_Part_3
go to the end of this article where you find section entitled 'Removing
Tools from the Palette'
I haven't tried it but assume it is a recommended way.
Swavek
""J
Re: Palette: how can I disable Note [message #149875 is a reply to message #149851] Tue, 11 September 2007 00:09 Go to previous message
Thanks Swavek,
This is indeed the correct way ;-)
-Arpit
Previous Topic:Label Missing after GMF 2.0 Upgrade
Next Topic:How do I restrict changes to the model based on attribute values?
Current Time: Sat Jul 19 23:18:38 EDT 2025
Powered by FUDForum. Page generated in 0.04389 seconds
