Home » Eclipse Projects » NatTable » Conditional Formatting for values calculated by the IGroupBySummaryProvider
Conditional Formatting for values calculated by the IGroupBySummaryProvider [message #1494773] Mon, 01 December 2014 13:59 Go to next message
I'm having trouble trying to add conditional formatting for values calculated by the IGroupBySummaryProvider. I'm trying to add a label that changes the foreground color to red for negative numbers. For normal data rows, I was able to get this working by comparing the cell's data value in an ILabelAccumulator. For GroupByObjects however, I overflow my stack when I try to get the aggregated value from the GroupByDataLayer in an ILabelAccumulator since the GroupByDataLayer calls the ILabelAccumulator itself.
Is there anyway implement this behavior in the current architecture?
Re: Conditional Formatting for values calculated by the IGroupBySummaryProvider [message #1494854 is a reply to message #1494773] Mon, 01 December 2014 15:28 Go to previous messageGo to next message
Doesn't look like that is possible at the moment.
Please create a ticket for this. I will have a look at the GroupBy stuff in general soon.
Re: Conditional Formatting for values calculated by the IGroupBySummaryProvider [message #1495702 is a reply to message #1494854] Tue, 02 December 2014 07:44 Go to previous messageGo to next message
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=453874
Let me know if you'd like any help implementing any of the remaining enhancements for the group by feature.
Re: Conditional Formatting for values calculated by the IGroupBySummaryProvider [message #1495731 is a reply to message #1495702] Tue, 02 December 2014 08:14 Go to previous message
Thanks! I will let you know if there is something you can help me with. Would like to see more support from the community. Smile
I guess I need to think about a whole refactoring of the GroupByObject itself. Maybe it needs to have more states than simply the value representation, like storing the summary provider for each column so it doesn't need to be requested all the time. Although I'm not sure if that arises other issues. Difficult task!
Previous Topic:Nattable resize issue
Next Topic:Issue with scroll bar for NatTable freeze command
Current Time: Sun Jul 20 14:55:43 EDT 2025
Powered by FUDForum. Page generated in 0.45994 seconds
