Home » Language IDEs » Java Development Tools (JDT) » can't format selections
can't format selections [message #14394] Mon, 05 May 2003 17:31 Go to next message
Originally posted by: travis.hume.tenzing.com
Using GTK+ v2.1.1 on Linux
Anyone else only able to format (Ctrl-Shift-f) full source files? If I
have an active text selection the shortcut (C-S-f) doesn't do anything,
the context-menu -> source menu doesn't contain a Format item, and the
Source menu doesn't contain a Format item.
Re: can't format selections [message #14860 is a reply to message #14394] Tue, 06 May 2003 06:00 Go to previous messageGo to next message
I believe the feature you are enquiring after has not been implemented.
Partial formatting is typically only needed if the formatter is not
very configurable - or doesn't work properly.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: can't format selections [message #15038 is a reply to message #14860] Tue, 06 May 2003 09:46 Go to previous messageGo to next message
Actually, this does work in Windows (and Motif too?). I think the trick is
that your selection has to start at column 0. I've found that if your
selection starts anywhere else, the menu item isn't available.
Re: can't format selections [message #15949 is a reply to message #15038] Tue, 06 May 2003 18:56 Go to previous message
You are correct sir! So much for double click to select a method and then
format. Oh well.
Thanks for the insight.
Marco Qualizza wrote:
> Tim Tyler wrote:
> >>have an active text selection the shortcut (C-S-f) doesn\'t do anything,
> >>the context-menu -> source menu doesn\'t contain a Format item, and the
> >>Source menu doesn\'t contain a Format item.
> that your selection has to start at column 0. I\'ve found that if your
> selection starts anywhere else, the menu item isn\'t available.
> > very configurable - or doesn\'t work properly.
Previous Topic:Debugger apparently does not work
Next Topic:Problems while debugging only ...
Current Time: Sat Jul 19 08:25:22 EDT 2025
Powered by FUDForum. Page generated in 0.06784 seconds
