Home » Eclipse Projects » Eclipse Platform » PDE: Preferences: default values not available
PDE: Preferences: default values not available [message #148504] Thu, 23 October 2003 11:27 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
myplugin.getPreferenceStore().getInt(Preferences.P_BLAH);
returns 0, i.e. the default value for an int.
This is because I did not change the default of P_BLAH which is 5000. So, if
I change the value of P_BLAH on the preference page the above call will
return 5000. Or: If I open the preference page prior to the above call it
will also return 5000.
Well, how am I going to do this correctly?
Timo
Re: Preferences: default values not available [message #148521 is a reply to message #148504] Thu, 23 October 2003 11:36 Go to previous messageGo to next message
If I understand what you are trying to do shouldn't you be using
IPreferenceStrore.getDefaultInt(Preferences.P_BLAH)?
HTH
Darins
"Timo Nentwig" <tcn@spamgourmet.com> wrote in message
news:bn8s0v$k8p$1@eclipse.org...
> Hi!
if
> Thanks
> Timo
Re: Preferences: default values not available [message #148538 is a reply to message #148521] Thu, 23 October 2003 11:52 Go to previous messageGo to next message
This returns the default value of P_BLAH, doesn't it?
Of course I want to get the value the user entered. But if the user didn't
change it I want the dafault value, of course...
Re: Preferences: default values not available [message #148555 is a reply to message #148538] Thu, 23 October 2003 12:01 Go to previous messageGo to next message
Sounds like you want to set the default value for your preference.
IPreferenceStore.setDefault(Preferences.P_BLAH, int)
Darins
news:bn8tfe$lv8$1@eclipse.org...
Re: Preferences: default values not available [message #148571 is a reply to message #148555] Thu, 23 October 2003 12:10 Go to previous messageGo to next message
?? No.
I want to get it. The default values are automatically set when the
preference page is once opened:
public Preferences() {
super(GRID);
setPreferenceStore(Plugin.getDefault().getPreferenceStore()) ;
setDescription("A demonstration of a preference page implementation");
initializeDefaults();
private void initializeDefaults() {
IPreferenceStore store = getPreferenceStore();
store.setDefault(P_BLAH, 5000);
But initializeDefaults() is only called when I open the preferenc page,
right? So, I don't know how eclipse does handle this internally or how it
does make changes to the preferences persistent, but the sense of a
preference page is to change the values, not to be called each time I want
to know them in order to use them...
I just need the value of P_BLAH in order for the plugin to work.
Re: Preferences: default values not available [message #148579 is a reply to message #148571] Thu, 23 October 2003 12:30 Go to previous messageGo to next message
You need to move your initialization out of being tied to opening the
preference page.
We initialize our preferences (as all plugins should) using
AbstractUIPlugin.initializeDefaultPreferences(IPreferenceSto re) or
Plugin.initializeDefaultPluginPreferences depending on which type hierarchy
your plugin is involved with.
Darins
news:bn8ug4$n0n$1@eclipse.org...
> ?? No.
> super(GRID);
implementation");
Re: Preferences: default values not available [message #148587 is a reply to message #148579] Thu, 23 October 2003 12:36 Go to previous messageGo to next message
> preference page.
> hierarchy your plugin is involved with.
public Plugin(IPluginDescriptor descriptor)
super(descriptor);
plugin = this;
// neither this
initializeDefaultPluginPreferences();
// nor that
initializeDefaultPreferences(getPreferenceStore());
// does help :-(
Re: Preferences: default values not available [message #148602 is a reply to message #148587] Thu, 23 October 2003 12:50 Go to previous messageGo to next message
You do not need to call these methods...part of the plugin lifecycle.
What does your implementation of these methods look like?
Darins
news:bn9028$op0$1@eclipse.org...
> > preference page.
> super(descriptor);
> plugin = this;
> // neither this
> // nor that
> // does help :-(
Re: Preferences: default values not available [message #148615 is a reply to message #148602] Thu, 23 October 2003 12:52 Go to previous messageGo to next message
Now I'm completely confused :-) You mean, I need to implement
initializeDefaultPluginPreferences() myself?? And what shall I do within
it? I canno call the initialize method of the Preference class...
Can you post a simple example snippet?
Re: Preferences: default values not available [message #148623 is a reply to message #148615] Thu, 23 October 2003 12:58 Go to previous messageGo to next message
Use the source...see DebugUIPlugin
Darins
news:bn90uo$pec$1@eclipse.org...
Re: Preferences: default values not available [message #148631 is a reply to message #148623] Thu, 23 October 2003 13:15 Go to previous messageGo to next message
Thanks.
It's somewhat strange code that's being generated by eclipse' wizard.
And how besides newbies does use wizards??
Anyway...
Re: Preferences: default values not available [message #148729 is a reply to message #148631] Thu, 23 October 2003 16:15 Go to previous message
Originally posted by: bob.objfac.com
Here's a snippet. In your plugin class:
protected void initializeDefaultPreferences(IPreferenceStore store) {
PreferenceConverter.setDefault(store, Constants.ID_COMMENT,
Constants.COMMENT_RGB);
store.setDefault(Constants.ID_TAB_WIDTH, 2);
Bob Foster
news:bn92an$r09$1@eclipse.org...
> Thanks.
> Anyway...
Previous Topic:How to distribute native DLLs with my pligin.
Next Topic:Scroll to line in TextEditor
Current Time: Sat Jul 19 10:43:36 EDT 2025
Powered by FUDForum. Page generated in 0.06463 seconds
