Home » Eclipse Projects » GEF » Zoom performance and connectors
Zoom performance and connectors [message #148276] Fri, 20 August 2004 15:01 Go to next message
Originally posted by: none.bphnx.com
Has anyone noticed any performance issues with Zoom?
Using the logic example, I programatically created 1000 XORGate objects
(10 X 100) and created around 20,000 connections. When I zoom in and out
on this drawing it takes over 1 minute to perform the operation and the
CPU is running around 100%. This is on a P4 2GHz 512MB RAM machine.
The problem seems to come from how many connectors you have. I decreased
the number of connectors by half and then it only took 10-15 seconds to
zoom. Then I decreased the connectors to only 1 per object and the zoom
was nearly instant.
Has anyone seen this before?
Re: Zoom performance and connectors [message #148317 is a reply to message #148276] Mon, 23 August 2004 10:55 Go to previous messageGo to next message
The reason is that connection routing is occurring when zoom changes. Which
connection router do you have activated? The shortest-path connection
router has something like O(n*n*n*n) performance characterstics, so I'm not
surprised.
I have unreleased code which will prevent this type of routing during zoom
level changes. I need to make it compatible, as discussed here:
http://dev.eclipse.org/mhonarc/lists/gef-dev/msg00390.html
"bandrews" <none@bphnx.com> wrote in message
news:cg5hr5$259$1@eclipse.org...
> was nearly instant.
Re: Zoom performance and connectors [message #148325 is a reply to message #148317] Mon, 23 August 2004 13:06 Go to previous messageGo to next message
I am using the ShortestPathConnectionRouter in the logic sample. I
switched it to the ManhattanConnectionRouter and now the zoom is only 3-5
seconds. Big difference! Do you know if this problem is logged already? I
did a search on "zoom" and bugzilla turned up nothing. So basically the
problem is routing should not occur while zooming?
thanks,
Barry
> surprised.
> > was nearly instant.
Re: Zoom performance and connectors [message #148333 is a reply to message #148325] Mon, 23 August 2004 15:40 Go to previous message
The anchors in the logic example already have a check in them to ignore zoom
changes. The problem is that the size of the primary layer is changing.
I thought I had logged this problem once, but I relogged it this morning:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=72436
news:cgd87a$vlh$1@eclipse.org...
> thanks,
> Barry
Which
not
> > surprised.
zoom
objects
out
the
decreased
to
zoom
> > > was nearly instant.
Previous Topic:How can Implement Copy, Paste?
Next Topic:GEF Logic Example
Current Time: Sat Jul 19 22:58:37 EDT 2025
Powered by FUDForum. Page generated in 0.04901 seconds
