Home » Eclipse Projects » Sirius » Sirius editor with Kieler/KLay layouter resizes nodes
Sirius editor with Kieler/KLay layouter resizes nodes [message #1480589] Thu, 20 November 2014 04:57 Go to next message
I have been trying to use the Kieler layout algorithms on diagrams that are created by a Sirius based editor.
Each time I relayout the diagram, using the Kieler based layout algorithm, diagram nodes are resized; they are enlarged.
I suspect that this is a problem of the Kieler layout algorithms but I want to know whether anyone has also tried this and if someone has found a solution for this issue already.
Greetings,
Wilbert
Re: Sirius editor with Kieler/KLay layouter resizes nodes [message #1480632 is a reply to message #1480589] Thu, 20 November 2014 05:36 Go to previous messageGo to next message
Le 20/11/2014 10:57, Wilbert Alberts a écrit :
> http://rtsys.informatik.uni-kiel.de/confluence/display/KIELER/KIELER+Layoutlayout
We have tried this layout a while ago. But it does not cover all the
Sirius cases (border nodes for example). We have no clue about your problem.
You could try to make the same on a pure GMF diagram and report a bug on
Kieler if you always have the problem.
> Greetings,
> Wilbert
Laurent
Laurent - Obeo
Need professional services for Sirius?
Re: Sirius editor with Kieler/KLay layouter resizes nodes [message #1482275 is a reply to message #1480632] Fri, 21 November 2014 11:42 Go to previous messageGo to next message
OK
I think I found something.
For some reasons, the Kieler (layered) layout algorithm considers each node to be a subgraph on its own. If the diagram is layouted, it first starts layouting its subgraphs and then the graph itself. The layout algorithm can be configured using properties. In fact, each item on the graph can have some properties. One of them is the Border Spacing which has a default value is 12.
So whenever a diagram is layouted, first all nodes are 'layouted'. As they are considered to be sugraphs, the Border Spacing property is applied which increases the size of the subgraphs with 24 pixels (12 on each side). Then the nodes on the diagram themselves are relayouted, taking the new size into account.
I am not sure whether the Sirius editor does something that leads Kieler to the conclusion that each node is a subgraph on its own or that Kieler interprets the Sirius generated diagram wrongly. So I'm not sure 'who to blame'.
So I think that I have a (manual) workaround. After displaying the graph for the first time, I need to select all nodes and set their border spacing property to zero. Selecting all nodes can be done with one action so that makes this workable.
I'm open for any additional suggestions.
Greetings,
Wilbert.
Re: Sirius editor with Kieler/KLay layouter resizes nodes [message #1602104 is a reply to message #1482275] Thu, 05 February 2015 05:24 Go to previous messageGo to next message
I have found one solution to resize issue, if we enable canLayout() feature to false, we can stop re-sizing during Layout.
Re: Sirius editor with Kieler/KLay layouter resizes nodes [message #1701233 is a reply to message #1602104] Fri, 10 July 2015 03:04 Go to previous messageGo to next message
For a few months now you've posted this topic. I want to use Kieler layouts on Sirius Diagram but i can not find documentation. Can you help me and tell me what I should do?
I have open a specific topic for that : https://www.eclipse.org/forums/index.php/m/1701150/?srch=kieler#msg_1701150
thank you
Re: Sirius editor with Kieler/KLay layouter resizes nodes [message #1727869 is a reply to message #1602104] Mon, 28 March 2016 13:38 Go to previous message
Hi Abhishek,
Where do we need to set canLayout() feature to false ? Could you please elaborate a little bit on this feature ? is it Sirius feature or Kieler feature ?
Parsa
Previous Topic:Sirius-Xtext-Integration doesn't work for Transitions and Edge
Next Topic:Deploy the "Ecore Model Project" and "Viewpoint Specification Project"
Current Time: Sat Jul 19 20:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.03860 seconds
