Home » Language IDEs » ServerTools (WTP) » Editor extending StructuredTextEditorXML and the print icon is disabled
Editor extending StructuredTextEditorXML and the print icon is disabled [message #144976] Mon, 24 October 2005 12:31 Go to next message
My editor extends StructuredTextEditorXML and the print button is disabled
when in my editor. What would cause this? Anything else that might be
disabled that I havent found yet? Any ideas would be appreciated.
Brian Jakubik
Re: Editor extending StructuredTextEditorXML and the print icon is disabled [message #145204 is a reply to message #144976] Wed, 26 October 2005 14:26 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
I think neither StructuredTextEditor nor StructuredTextEditorXML do anything
special with the print action. Are you able to do everything else just fine
in your editor? Also, as a heads up, StructuredTextEditorXML is gone (as of
WTP 1.0 M8.) There were instructions posted in the wtp-dev mailing list on
what to do instead. But the short version of it is that you should be using
StructuredTextEditor instead. And actually, you should not be subclassing
that class but instead, use its extension points and such to extend the
editor. See http://eclipse.org/webtools/wst/components/sse/overview.html
"Brian Jakubik" <brian.jakubik@intervoice.com> wrote in message
news:djj22l$rs6$1@news.eclipse.org...
> Brian Jakubik
Re: Editor extending StructuredTextEditorXML and the print icon is disabled [message #145331 is a reply to message #144976] Wed, 26 October 2005 22:28 Go to previous messageGo to next message
It's very likely that you left out the editor action contributor
where you defined your editor in your plugin.xml. The
BasicTextEditorActionContributor is responsible for setting up the
global print action so that it routes to the SourceViewer's print
operation.
- Nitin
Re: Editor extending StructuredTextEditorXML and the print icon is disabled [message #148163 is a reply to message #145331] Mon, 21 November 2005 11:47 Go to previous message
You are correct, that fixed my problem. Thanks
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:djpe0v$9po$1@news.eclipse.org...
>> disabled when in my editor. What would cause this? Anything else that
>> might be disabled that I havent found yet? Any ideas would be
>> appreciated.
> It's very likely that you left out the editor action contributor where you
> BasicTextEditorActionContributor is responsible for setting up the global
> print action so that it routes to the SourceViewer's print operation.
> - Nitin
Previous Topic:Setting up a workspace for WTP Development
Next Topic:JSP Editor error
Current Time: Sat Jul 19 23:54:03 EDT 2025
Powered by FUDForum. Page generated in 0.04396 seconds
